3 gauge pillar pod installed
Old Nov 9, 2007 | 12:24 PM
dan96z71's Avatar
Default 3 gauge pillar pod installed
First off I don't know if I am really going to like it, but we will see. Seems like it is right there in your face all the time.
I got the paint from Napa. They had a can matched up for the interior color. GM code was 69 Very Dark Pewter. I used some adhesion promoter on the plastic and then a couple coats with the color. That came out good.
Nothing is hooked up yet, just have the pod and gauges installed.
Man those pictures really came out bad!
Old Nov 9, 2007 | 12:26 PM
KevinF56's Avatar
boost gauge, eh? what are you planning?
Old Nov 9, 2007 | 12:32 PM
Phantom's Avatar
11 Second Club
i don't like mine either...
Old Nov 9, 2007 | 12:34 PM
usabodyguard's Avatar
Blown 427 LSX
hey wait a sec... i was thinking about doing a 3 gauge pod...why are you guys hating it??
thanks...
dan96z71's Avatar
https://www.performancetrucks.net/fo...d.php?t=404739
Boost is just for show. Figure I will hook it up to my lumbar support pump and see how much boost it puts out.
I hate it because it sticks out to far. Feel like I am going to crack my head on it. And to read the top gauge I just about have to look sideways. Hindsight I might go with the socaldiesel ones in the center overhead console...just a thought.
Someone needs to make a gauge cluster where you can pick what gauges you want in it and order it up with only the ones you want. Someone has got to be able to do that.
Old Nov 9, 2007 | 12:44 PM
Blown 427 LSX
hmmmm if i had to go with only two gauges what would you suggest... i have a trans gauge in dash...
wideband and boost?
Old Nov 9, 2007 | 12:45 PM
larsy87's Avatar
apple bottom jeans
I have the 2 gauge one and it gets in my way but the gauges are easily readable...but they rarely change( AFR and tranny). I
Old Nov 9, 2007 | 12:55 PM
dan96z71's Avatar
2 gauges I would go with wideband and boost. I was trying to decide if I wanted a fuel pressure one also, but decided against it. Hopefully I will be able to keep an eye on things with the wideband.
Go with the 2 gauges (wb and boost) and get the socaldiesel pod would be my suggestion.
Old Nov 9, 2007 | 01:57 PM
larsy87's Avatar
apple bottom jeans
I don't get the boost without FI...kind of ricey man, if your going to have gauges you might as well have useful ones IMO
Old Nov 9, 2007 | 02:02 PM
BlackGMC's Avatar
Resident Retard
IMO you should research or think before you call someone ricey... this does not look ricey to me....
https://www.performancetrucks.net/fo...d.php?t=404763
