265/35/22 or 285/35/22
Old Nov 5, 2005 | 07:36 PM
Last Call's Avatar
TOTM: January 2007
Here is some additional info;
The Pirelli 265/35R22 outside diameter is 29.4 inches according to there website.
http://www.us.pirelli.com/en_US/tyre...productid=9905
The Nitto 285/35R22 outside diameter is 29.88 inches accoding to there website.
http://www.nittotire.com/tires_555.asp
I dont think the additional .58 of an inch is going to make that big of a difference. With a bigger tire, the truck will ride better and the risk of creating curb rash on your rims is reduced because the tire is wider. I know everyone usually goes with a 265, but I think a 285 will work.
Old Nov 5, 2005 | 08:46 PM
Fogle07's Avatar
twankydeuce do your tires rub any with that drop?
Old Nov 5, 2005 | 09:43 PM
angelofdeath's Avatar
sup jason! i'm tryin to make this 285/35 fit a 4/6. do u think it can happen? i know its stupid to some people! but how bad is it gonna scrape? that link u posted helped a lot. it's really not that much of a difference. dang! i need to sit on this.....
by the way have u decided how much u sellin the hangers and shackles for?
Old Nov 6, 2005 | 02:58 AM
TWANKYDEUCE's Avatar
nope, but only because I have the correct backspacing on my wheels
Old Nov 6, 2005 | 08:35 AM
Fogle07's Avatar
what backspacing do i need when i go up to 22's?
Old Nov 6, 2005 | 11:47 AM
Last Call's Avatar
TOTM: January 2007
I think it is 25mm or 6.25 inches on a 9.5 inch rim.
Old Nov 6, 2005 | 12:33 PM
"twanky" what backspacing do u have in your rims?
Old Nov 6, 2005 | 03:55 PM
Gran Patron's Avatar
What width can you go with 22's up front?
I tought the 285's only fit on a 22x10 wheel? I did some research and found out the 22x10's up front will give you some rubbing issues and touches the front sway bar. And you would be better off with a 22x8.5 wheel size up front,the only thing is there's not to many manufactures that make a 22x8.5!
Old Nov 6, 2005 | 10:56 PM
Last Call's Avatar
TOTM: January 2007
Both a 22x9.5 and 22x10 will work. I have the 22x9.5 and brother has 22x10's on his VHO. The tire size is more important than the rim width. I had 285/35's mounted on my 22x9.5 for 2 years and experienced zero rubbing issues with a 3/4 drop. I now have 305/35's on my 22x9.5's and have slight rubbing issues on the left side only. But that is with a 30.6" tall tire on a 3 inch front drop.
I will take some pictures between the sway bar and the rim tomorrow of both my truck and my bros, that will give us some answers.
Old Nov 6, 2005 | 11:41 PM
sweet! right on Jason! i think 285's might work!
