2/4 or 4/6
Old May 28, 2005 | 08:40 PM
04blackvho's Avatar
Default 2/4 or 4/6
well im thinking of doing a drop just not sure on the size of the drop i have the vho rims with 285/50/20 what drop would you all use.what is c-notching the fame mean
Old May 28, 2005 | 08:45 PM
Dub Silverado's Avatar
YOu wont get those wheels and tires on a 4/6 truck. 4/6 looks better i think than a 2/4, but will be more expensive, less ride quality, and less ground clearance. C notch is when you cut a notch out of the rear frame and then reinforce it with a bolt on bracket. It is notched so the axle has room to travel without bottoming out.
Old May 28, 2005 | 08:47 PM
04blackvho's Avatar
what size tire will fit on a 4/6 with 20 inch rim
Old May 28, 2005 | 08:52 PM
255/35, 285/30 265/30 265/35 one of those i guess, maybe you could make some others work. 275/45 will work, but will rub some
Old May 28, 2005 | 08:58 PM
04blackvho's Avatar
what drop do you have
Old May 28, 2005 | 09:00 PM
i have the Hotchkis 2.5/4 with extra 2 inch shackles in the back. It makes it about a 3/6. I have 265/40/22 tires.
Old May 28, 2005 | 11:42 PM
Y2KSierra's Avatar
4/6 no question. 2/4 trucks just aren't very low, at least to my eyes.
Dub Silverado is right, those tires don't have a chance on a 4/6 and might be a bit much even for 2/4. If going 4/6 go with 255/35 and 2/4 you can run 275/45 and be OK.
Old May 29, 2005 | 12:54 AM
Depends on how the rd is id say go with a 4/6 but if you live were theres speed bumps potholes etc etc go with a 2/4 why just dont get a 3/5!
Old May 29, 2005 | 01:46 AM
Ross @ EDO's Avatar
FormerVendor
Id like to go lower, but im not cutting the frame on my new truck. Im pretty much very happy with my 3/4.5 drop.
Old May 29, 2005 | 10:51 AM
TXsilverado's Avatar
just settle in the middle and get a 3/4.
