2 / 2 Questions
Old Jul 26, 2005 | 05:19 PM
NSI31's Avatar
Default 2 / 2 Questions
If I use 2" drop springs on the front and 2" drop shackles (or blocks) on the rear...('00 Silvy) will the front end need any adjustments??
Would this look o.k. with stock wheels / tires (for now ?)
Any pics of 2/2 drops ??
Old Jul 26, 2005 | 05:41 PM
EDawg's Avatar
if your droping a ne w silverado you need hangers and shackles in the rear. you will need a frontend alignment nomatter what!!!
Old Jul 26, 2005 | 09:01 PM
TWANKYDEUCE's Avatar
For a 2" rear drop all you need is shackles. No matter what you do to the front, lift, drop, you always will need an alignment.
Old Jul 27, 2005 | 04:21 AM
ap2002's Avatar
i did a 1/2 drop on mine and it sits up just right with the stocker or the 20's... I think if you go 2/2 then you would be able to tell quite abit that it is lower in the front...
Old Jul 27, 2005 | 12:24 PM
duwem's Avatar
2-2 drop in the works, rear done, front this weekend, shackles and lower control arms on stock rims/tires. I will change my sig pict when i get it done.
Old Jul 27, 2005 | 12:35 PM
leochevy2001's Avatar
a guy at work has a 2/2 drop on his truck and to me it doesn't look right. the rear has too much fender gap and the front wheels tuck. i wish i had a way to take a pic of it for you to see.
Old Jul 27, 2005 | 01:18 PM
ap2002's Avatar
i agree.....
Old Jul 28, 2005 | 12:50 AM
blackbyrd's Avatar
i was considering a 2/4 drop on my 05 silverado (already did shackles in the back) so for now it is balanced. do you guys think 2 inch in the front is to much if i were to put 22's on it?
Old Jul 28, 2005 | 01:05 AM
graystepside's Avatar
this truck here is dropped 2 inches in the front and rear.
https://www.performancetrucks.net/fo...d.php?t=345357
Old Jul 28, 2005 | 06:52 AM
The guy at work is rolling 20s and is an extended cab which makes it look totally different than that.
