11 inch wide rims on lowered truck
Old Aug 12, 2018 | 10:40 PM
92SS Wagon's Avatar
Default 11 inch wide rims on lowered truck
I have some 17" Budnik wheels that I want to stretch out to 11" wide for the rear of my truck to run a wider
tire. Will this combination fit without have to cut anything? My truck is lowered 4/6 right now. Just not sure if the width will work or not I appreciate the help
Old Aug 12, 2018 | 10:45 PM
FFDP's Avatar
Grab a tape measure and find out?
Add whatever length you need to the back side and see if it touches the leaf springs.
Old Aug 13, 2018 | 09:54 AM
Vortec350ss's Avatar
yea its going to depend on the specs of the wheel currently. Stock leafs get tight depending on the tire with more than 7.5" backspacing
Old Aug 13, 2018 | 07:56 PM
92SS Wagon's Avatar
Sorry guys I wasn't intending for someone to do the work for me I should have clarified. I was just looking for help in figuring out if it was possible or not.from the outside lip on my current rim that is 8.5" wide I have roughly 4" from the outer lip to Leaf Spring
Old Aug 13, 2018 | 08:02 PM
FFDP's Avatar
In theory you should be able to reach that 10.5-11in wide wheel with that much room still. Even with tire flex you'll have more than 1in to work with.
Shouldn't have to cut a thing because you are making the rim wider inside the wheel well and not pushing the rim outwards towards the fender.
Old Aug 16, 2018 | 06:21 AM
92SS Wagon's Avatar
Thanks man I appreciate it. I remeasured everything and emailed Budnik they said they could help me figure it as well I'm hoping I can make this work.
Old Aug 16, 2018 | 09:56 AM
ss4chad's Avatar
12 Second Club
I have Centerline wheels, 20x8.5 that I widened in the rear to 20x10. I got all the room in the world, currently using 295/35 20 but going to a 315/35 20 as soon as I burn these off!
Chad
Old Aug 16, 2018 | 12:01 PM
I have 15x11's on my truck with 315 pro's and it fills the wheel well. The tires are huge... but I had to trim my leafs and stretch the bed. It looks amazing, but it took work.
7.5" backspace.
Old Aug 21, 2018 | 06:32 AM
92SS Wagon's Avatar
Chad
Thanks I appreciate it! I wish I could go 10" but Budnik says with the face on my wheels its either 8.5 or 11 there is nothing in between
7.5" backspace.
any chance you can share some pics? How do you trim leaf springs? never heard that before.
Old Aug 21, 2018 | 08:29 PM
I dont have any of my leafs.
Check out this thread though, it has a good example of what I did and pics of my current truck.
https://www.performancetrucks.net/fo...adials-551802/
LPRacing
May 10, 2012 08:11 PM
loloone
14
Dec 14, 2011 11:02 AM
getchusum99
Sep 29, 2011 10:40 AM
02Vortech
Feb 10, 2007 12:58 AM
