10.5 MT ET Streets on a 7 inch wheel?
Old Apr 7, 2003 | 10:00 AM
StreetSweepa's Avatar
Default 10.5 MT ET Streets on a 7 inch wheel?
Just wondering if the 10.5 inch drag radial would fit on a 7 inch wheel?
Old Apr 7, 2003 | 10:09 AM
creederado's Avatar
Default Re: 10.5 MT ET Streets on a 7 inch wheel?
MT suggests taking the tread witdh and using a rim +or - 1". If your looking for a 28" tall tire they only have 11.50 or 12.5 on a 16" rim. On the 11.50 tire the tread width is 8.7" They suggest 7-9 rim.
www.mickeythompsontires.com
I think some here are even running 26-11.50/10.50 on the 6.5 stock steel w/out problems.
Are you planning to use the 7" stock aluminum? Try it, you can always uprade to a 8" rim for cheap. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
If your're looking at the bfg drag radials I believe the 255/50 16 suggest a 6.5-9.5 rim.
The tire sites should have the rim requirements posted.
<small>[ April 07, 2003, 10:12 AM: Message edited by: creederado ]</small>
Old Apr 9, 2003 | 09:32 AM
So.....An 11.5 inch tire will work on a 7 inch wheel as well?
Old Apr 10, 2003 | 08:20 AM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StreetSweepa:
<strong> So.....An 11.5 inch tire will work on a 7 inch wheel as well? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, I've seen it done. But a wider whell will get you a better contact patch.
Old Apr 10, 2003 | 10:14 AM
I've got 11.5's on the stock rim and they work fine.
Corvette454l88
Sep 1, 2016 01:24 AM
southernsmoker
Aug 31, 2015 03:09 PM
WhoAteMySoup
Aug 20, 2015 09:52 AM
LETHL_SS
Aug 16, 2015 06:58 PM
