'01 rcsb
Old Apr 29, 2011 | 08:06 PM
  #21
silverado-lover's Avatar
The percentage of transmissions that grenade
Old Apr 29, 2011 | 08:16 PM
  #22
custm2500's Avatar
Ph.D. in HUBRIS
Strength is the main thing. First gear is a slightly differant. Overall size is differant so you need to modify or buy a crossmember.
Some guys run built 60s behind a ton of power and do ok. Others have ultra bad *** 60Es go to hell with minimal power going through them. Again a plan is your best asset to decide how much you have to spend and how much you need.
Old Apr 29, 2011 | 08:17 PM
  #23
custm2500's Avatar
Ph.D. in HUBRIS
This is a good answer! just not descriptive enough for a self proclaimed noob!
Old Apr 29, 2011 | 08:37 PM
  #24
Go back in your corner
Old Apr 29, 2011 | 08:58 PM
  #25
monkeymanstunna's Avatar
lol thanks for the info guys.
Got another question for you. I want to do the 2/4 drop but my truck has the check lean on the drive front. when i order my spindles and shackles/hanger kit that alno will not fix the problem, and i still need to get the GM spacer or belltechs spacer to fix the problem to level out the truck...is that right? I heard "raise the front and the rear will follow", i say that because the left rear is lower than the right as well.
thanks
Old Apr 30, 2011 | 04:43 AM
  #26
Spoolin's Avatar
GFYS and STFU
Beautiful truck OP, looks like it was really well maintained. That is my favorite year silvy.
And your description is better? you didn't address one mechanical differnce other than it's physical size and different 1st gear size. Bravo
Old Apr 30, 2011 | 09:05 AM
  #27
custm2500's Avatar
Ph.D. in HUBRIS
I explained the three main differences that matter to you swapping between them.
I was trying to be funny. And as always this forum is full of *** holes. I have spent a lot of time on a lot of forums and this is by far the worst forum I have ever looked at. There is some good info and great looking trucks, but that is clearly overshadowed by caliber and maturity of the members.
Old Apr 30, 2011 | 09:50 AM
  #28
Old Apr 30, 2011 | 11:01 AM
  #29
custm2500's Avatar
Ph.D. in HUBRIS
No just tired of the rudeness.
Old Apr 30, 2011 | 12:45 PM
  #30
Wow, this thread got a little out of hand. It's all good guys. I still thank all you guys for the replies.
Has anyone had a chancto look at my lastest question?I want to do the 2/4 drop but my truck has the check lean on the drive front. when i order my spindles and shackles/hanger kit that alno will not fix the problem, and i still need to get the GM spacer or belltechs spacer to fix the problem to level out the truck...is that right? I heard "raise the front and the rear will follow", i say that because the left rear is lower than the right as well.thanks
