QUALITY PICS OF YOUR TRUCK!!! Post a (OR COUPLE) pic(s) of your truck in here. SHHH no talking, just pics. You never know, you may get picked for a TOTM nomination or even make the calendar!
Rcsb Duramax
Old Oct 26, 2018 | 11:06 PM
stylinfosho's Avatar
Default Rcsb Duramax
Old Oct 27, 2018 | 11:17 AM
treylittlefield's Avatar
Looks good! Post up some more pictures and info
Old Oct 28, 2018 | 05:55 PM
Old Oct 28, 2018 | 06:03 PM
Lly korey Willis dsp5 fass150 s&b intake larger intercooler tubes rbp header 4 inch downpipe stock turbo thays about it. Everything was moved forward and rear of frame was cut. Its a tire shredding machine
Old Oct 28, 2018 | 06:15 PM
dantheman1540's Avatar
Thing is beautiful! Is it 4x4? and did you keep the alison?
Old Oct 28, 2018 | 06:28 PM
Nope its a 2wd and yes has the Allison stock for the moment built trans is next on the list and I'm considering coverting it to 6 lug so I can run some oem 20s to make it look even more like a half ton
Old Oct 28, 2018 | 06:57 PM
That would be pretty sneaky but I think the stack gives it away a bit!
Anything done suspension wise?
Old Oct 28, 2018 | 07:02 PM
2 inch shackle on rear spring removed bilstein shocks front de cranked flipped tie rod ends drop shocks rides like a covered
Wagon I will eventually 4 link the rear
Old Oct 28, 2018 | 07:06 PM
I'm in the process of trying to find stepside bed so I can re create my first truck i built 10 years ago.....but it was a 1500 and 4x4
Old Oct 28, 2018 | 07:12 PM
The step side would really make it look like a 1500.
I think the 2wd HD front ends are easy to convert to coilovers which would help ride quality a lot. What rear end is it Corp 14? did you put in a locker or anything?
