Yeeeuup...another turbo build
Old Jul 18, 2019 | 07:02 PM
  #61
Feed's Avatar
Originally Posted by kaze_v8
So how is it riding around with all that power and bagged?
How does the suspension respond to the power?
So far it's good but, It's only at 8psi with conservative timing.... might be 400whp? Its a kp components parallel 4 link...it had some wheel hop with stock motor. I expect to make some changes to it, eventually I'm going to fab up new frame/axle brackets so i can adjust instant center.
Old Jul 19, 2019 | 07:51 AM
  #62
ILuvJDM's Avatar
Do you have a BOV? I hear lots of what sounds like compressor surge in that video
Old Jul 19, 2019 | 08:02 AM
  #63
Feed's Avatar
Yes, i do have a BOV, I'm not sure it's working right. Haven't gotten a chance to look at it yet.
Old Jul 19, 2019 | 11:44 AM
  #64
kaze_v8's Avatar
Gotcha, yeah i figured something like that.
Im looking to bag mine soon, but with a 3 link wishbone setup, not sure how itll handle under boost
Old Jul 19, 2019 | 03:09 PM
  #65
Feed's Avatar
This is worth a read especially if you are doing the fab work. https://www.airsuspensionbook.com/
Only covers rear suspension volume 2 will be all about front setups.
Old Aug 18, 2019 | 09:55 PM
  #66
Feed's Avatar
Up to 14lbs... I'm going to add a little bit of timing and call it good. I think ive had the fuel tank in and out 6 or 7 times. Ditched the gates submersible hose for holley, not saying the gates hose is bad, I stretched it way out to fit the hose barb fittting i had and expected it to fail, but it failed sooner than i thought it would...Ditched the intank plug for walbro 450 fuel pump which failed and soldered the connections with heat shrink wrap. Cut a piece of the stock fuel line to cover positive wire splice.
Old Aug 18, 2019 | 10:13 PM
  #67
Feed's Avatar
Limped truck home on 25psi of fuel within half mile of home, then towed it home with my zero turn mower in the pouring rain.
Blow off valve was an easy fix. Plug on the right is what came in the box... missed getting the threads rolled. I emailed turbosmart and they sent a new one free of charge. Tried to find one locally but it must be BPT. I had it just forgot to put it in.
I bought this battery powered fuel pump to put diesel in my tractor since the loader arms are in the way, i love it and use it for everything since the epa gas cans are garbage. I almost miss the sweet burn gasoline in my mouth.
Old Aug 19, 2019 | 02:13 PM
  #68
Choda's Avatar
engine bay pics dont do it justice. Its spotless under the hood. Fantastic job man.
See you on the 28th at lancaster! My race truck vs yours!
Old Aug 20, 2019 | 05:30 PM
  #69
xKILLORADOx's Avatar
Do you have any pictures of the fuel pump wiring passing through the fuel hat or bulkhead? Very nice build BTW
Old Aug 20, 2019 | 08:22 PM
  #70
Feed's Avatar
I either got it from summit or Amazon. It didn't come up in my Amazon search tho. They are called cable glands.
