Whistle pig build
Old Nov 28, 2018 | 10:46 PM
  #211
ironcityboom's Avatar
Originally Posted by Atomic
That seems like a huge waste of space just for a couple switches but I can do it if you want
I know, I know! But I can put some holes in it later on if I decide to throw any extra gauges in. I originally was going to just cut a hole in the stock cluster.
Originally Posted by Jake75
What did you need to put the grant wheel on? I want to put one in my truck but haven't taken off the wheel to see how it mounts or what is needed.
There's a few different parts you'll need I think I listed them earlier in the thread but I may not have. Ultimately you'll get the Moroso quick disconnect and the shaft attachment it comes with will need welded on and it specifically stated that it needs Tig welded. After that it's a piece of cake.
Moroso 80160
Grant 673 Racing Wheel
Grant 3073 Wheel Adapter
Old Nov 28, 2018 | 10:49 PM
  #212
Jake75's Avatar
Moroso 80160
Just went back and looked. After i posted that i thought i remembered seeing it. Thanks for the part numbers
Old Nov 28, 2018 | 10:55 PM
  #213
No worries man!
Old Nov 29, 2018 | 12:50 AM
  #214
Atomic's Avatar
I have a gauge for that
I just used the steering wheel adapter from Grant to install my Grant wheel, part number GRT-5167, bolted right on.
Old Nov 29, 2018 | 10:08 AM
  #215
bottledls6's Avatar
what year is your truck ATOMIC?
Old Nov 29, 2018 | 10:16 AM
  #216
Boost-freak's Avatar
Originally Posted by Burnett03
Why are you guys going to the Holley instead of using hptuners or efi live on the factory ECM? Better features or just easier to use?
besides what the guys said , it also have more safety features .
Old Nov 29, 2018 | 11:25 AM
  #217
Atomic's Avatar
Its a 1999
Old Nov 29, 2018 | 10:32 PM
  #218
I don't think I had ever seen that particular adapter, when I called them they told me they didn't have anything that would bolt right up because it required removing the airbag and was a liability issue. Plus I wanted to be able to use a quick disconnect mount so I guess it worked out.
Old Nov 30, 2018 | 01:26 AM
  #219
Jake75's Avatar
I saw this on motion raceworks. I assume it would work also...
https://www.motionraceworks.com/coll...h-stock-column
Old Nov 30, 2018 | 02:35 AM
  #220
Atomic's Avatar
I just removed the airbag and let jesus take the wheel
