Whistle pig build
#201
I have a gauge for that
Yea I have a couple different versions, the holley version I have now does not have any holes for gauges (you can always drill holes if you want). I have a few on hand now just been waiting for pics before I release them. I actually forgot about them until this reminded me even though I walk past a stack of them every day because ive been busy with other stuff.
Found a pic:
AFP Holley Dash
Found a pic:
AFP Holley Dash
#204
HP Tuners and EFI work great and I have no complaints with the stock PCM. The stock PCM is very capable to make big power. The Holley Dominator, from what I've seen, has more capability and the ability to run a two step, trans brake, boost controller, nitrous, water/meth, traction control, etc, out of the one ECU. I'm very new to it but so far it's nice!
#205
The factory ECM is great for a factory setup, and can be made to work with higher power stuff, but does not come anywhere close to an aftermarket ECM geared towards racing with the amount of features and options you would want as a racer. The biggest hard stop with the factory ECU is usually the 30psi 3bar boost limit.
#206
Found a pic:
AFP Holley Dash
Found a pic:
AFP Holley Dash
This is is the switch board I have.
#208
Yep where the Holley would go is where I’d like to put the switches. I’m gonna keep my Holley where I have it just so I can actually see it, since I put the Grant steering wheel on it's alot smaller than the factory wheel so it obstructs the whole screen if I were to put it in the stock location with your bracket.
#210
