Whistle pig build
Old Nov 28, 2018 | 11:15 AM
  #201
Atomic's Avatar
I have a gauge for that
Yea I have a couple different versions, the holley version I have now does not have any holes for gauges (you can always drill holes if you want). I have a few on hand now just been waiting for pics before I release them. I actually forgot about them until this reminded me even though I walk past a stack of them every day because ive been busy with other stuff.
Found a pic:
AFP Holley Dash
Old Nov 28, 2018 | 02:55 PM
  #202
Burnett03's Avatar
Why are you guys going to the Holley instead of using hptuners or efi live on the factory ECM? Better features or just easier to use?
Old Nov 28, 2018 | 02:56 PM
  #203
Dusty05's Avatar
I'll be able to take / post some pics and send to Atomic on Sunday night or Monday when I get back in town! They are long over due...sorry man hahahah
Old Nov 28, 2018 | 03:02 PM
  #204
Dusty05's Avatar
HP Tuners and EFI work great and I have no complaints with the stock PCM. The stock PCM is very capable to make big power. The Holley Dominator, from what I've seen, has more capability and the ability to run a two step, trans brake, boost controller, nitrous, water/meth, traction control, etc, out of the one ECU. I'm very new to it but so far it's nice!
Old Nov 28, 2018 | 03:28 PM
  #205
Atomic's Avatar
The factory ECM is great for a factory setup, and can be made to work with higher power stuff, but does not come anywhere close to an aftermarket ECM geared towards racing with the amount of features and options you would want as a racer. The biggest hard stop with the factory ECU is usually the 30psi 3bar boost limit.
Old Nov 28, 2018 | 05:02 PM
  #206
ironcityboom's Avatar
Found a pic:
AFP Holley Dash
I definitely want one, preferably with a small square cut out in the center to flush mount my switch board. I'll have to get a measurement of the wires in the back, I know the overall dimensions but I don’t know how much thatd help you. I suppose we could take the overall dimensions and make the hole just slightly smaller perhaps just inside of the mounting holes.
This is is the switch board I have.
Old Nov 28, 2018 | 05:12 PM
  #207
Atomic's Avatar
What do you mean the center? Where the holley goes or beside it to one side?
Old Nov 28, 2018 | 05:51 PM
  #208
Yep where the Holley would go is where I’d like to put the switches. I’m gonna keep my Holley where I have it just so I can actually see it, since I put the Grant steering wheel on it's alot smaller than the factory wheel so it obstructs the whole screen if I were to put it in the stock location with your bracket.
Old Nov 28, 2018 | 10:03 PM
  #209
Atomic's Avatar
That seems like a huge waste of space just for a couple switches but I can do it if you want
Old Nov 28, 2018 | 10:26 PM
  #210
Jake75's Avatar
What did you need to put the grant wheel on? I want to put one in my truck but haven't taken off the wheel to see how it mounts or what is needed.
