Whistle pig build
Old Jan 21, 2018 | 07:36 PM
  #121
ironcityboom's Avatar
Originally Posted by Burnett03
What did you do for the turbo oil drain? Tap the pan or weld a bung? And where? Thanks
Just a -10an Drain to a weld in bung in the front of the pan
Old Jan 21, 2018 | 08:52 PM
  #122
Atomic's Avatar
I have a gauge for that
Originally Posted by ironcityboom
Hey she runs...now if I could just find someone to tune it
Is this really still an issue? You need to PM me
Old Jan 22, 2018 | 10:42 AM
  #123
Reckless's Avatar
Still moddin'
Curious what has to be done to the column to remove the factory shifter handle? I am thinking of mounting a shifter in the center console on mine. I don't have a manual valve body on my 4L80, but mostly want it for a custom look. I assume the plastic cover is available for the column (without the shifter hole)? Otherwise the neutral safety and gear indicator are all built in to the switch on the trans as far as I know?
Seems like a can just run the B&M cable down there and connect it and everything will work "like stock".
Eventually I will probably go to a Pro EFI setup on the truck and completely rewire like you did. Great build by the way!
Old Jan 23, 2018 | 05:10 AM
  #124
1FastBrick's Avatar
Custm2500's Rude Friend
I believe there is a pin you just drive out to get the handle off. Then get a steering column cover for a manual trans truck.
This is an 04 truck but the 99-02 is similar.
https://www.performancetrucks.net/fo...8/#post5306303
Old Jan 23, 2018 | 08:53 AM
  #125
Reckless's Avatar
Still moddin'
Very helpful thank you. Did you source the column plastic pieces and handle cover thingy from GM?
Old Jan 23, 2018 | 06:49 PM
  #126
1FastBrick's Avatar
Yes, that's what the person in that thread did.
If you can find a 99-02 truck with a manual trans, you can use the vin to get the correct part number for your truck.
Old Jan 23, 2018 | 10:11 PM
  #127
crashmymax's Avatar
What type of 90* did you use on your heater hoses? Been looking for somthing like that.
Truck looks amazing!!
Old Jan 24, 2018 | 11:03 AM
  #128
Reckless's Avatar
Still moddin'
Unfortunately the part is no longer available for order (discontinued) just as many parts for these trucks. Had to find my console parts from salvage yards. Guess I'll have to do the the same for the column covers
SORRY FOR THE HIJACK!
Old Jan 24, 2018 | 11:55 AM
  #129
1FastBrick's Avatar
Sometimes there still in stock at a dealer. I have had my local dealer locate the part for me, then I contact the stocking dealer and have them see if the part is still on there shelf. I have had dealerships ship me discontinued stuff from across the country.
Those trucks are a rarity out her in California, But should I see one I will grab it
Old Jan 24, 2018 | 02:56 PM
  #130
Reckless's Avatar
Still moddin'
Thanks I will check with our local GM parts dealer and see what they can find out.
