Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Oct 6, 2016 | 02:26 PM
  #961
Vortec350ss's Avatar
Originally Posted by BigKID
I'll be glad when we get some 50 degree air! Glad to see it is back together and working well.
Your truck would haul *** with 50* air! Man it was running like a bat out of hell at LS fest too and that air sucked...
Old Oct 7, 2016 | 12:53 AM
  #962
Blown06's Avatar
8 Second Truck Club
The aftermarket parts are designed with looser clearances and will pressurize the block quicker, therefore sending more oil into a catch can. I also have the Holley valve covers that are notorious for having issues like that.
My catch can is designed to go from the valve cover to the TOP of the catch can where it has a filtration system that hangs down about 2" that is designed to turn vapor into oil liquid. The outlet port on the side of the can is above the bottom of the filtration system and that goes to the vacuum port on my blower.
We was just discussing this sort of thing in Petraszewsky's thread. Hopefully he is reading over here too.
Data log crankcase press/vac with and without the line hooked up to the intake. In the unhooked scenario just let it vent to atmosphere.
Old Oct 9, 2016 | 01:26 PM
  #963
How are people data logging that?
Old Oct 9, 2016 | 06:13 PM
  #964
03sierraslt's Avatar
What sensor is that?
Old Oct 9, 2016 | 06:32 PM
  #965
mikevanky's Avatar
Rob how is the cleaning solution working out on the intercooler?
Old Oct 9, 2016 | 08:20 PM
  #966
It definitely worked. It didnt have a drastic effect on my IAT, but I'm glad i went through the effort... peace of mind if nothing else.
Old Oct 10, 2016 | 12:29 AM
  #967
Blown06's Avatar
8 Second Truck Club
A 2 bar map sensor should work just fine.
Old Oct 10, 2016 | 10:18 AM
  #968
So your saying some is adding in a sensor to monitor it. Right.
I thought you were implying that it could be monitored in stock form. That's why I was lost.
Old Oct 11, 2016 | 12:50 AM
  #969
Blown06's Avatar
8 Second Truck Club
Sorry to confuse. No, to my knowledge there is no way to log in stock form. You'll have to add a 2 bar sensor somewhere, like maybe in the valley plate. You use a 2 bar because it'll show vacuum and pressure.
Old Oct 11, 2016 | 08:01 AM
  #970
Atomic's Avatar
I have a gauge for that
That wouldnt be hard at all actually. The stock PCMs have EGR, and AC pressure on 5v inputs that can be hijacked temporarily. I have my methanol pressure going through my ac pressure via a transducer I got off ebay. Would be very easy to do the same thing for crank case pressure.
