Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Nov 23, 2015 | 10:44 AM
  #611
GMCtrk's Avatar
Two walbro 450 pumps must draw some serious voltage because once my second one comes on the exterior and interior lights dim. Both are wired directly to the alt on racetronix hotwire kits. 145 alt
Old Nov 23, 2015 | 10:54 AM
  #612
Atomic's Avatar
I have a gauge for that
I think at 90psi they draw close to 22 amps each, at 0psi its around 14amps each. So yea if you are racing at night, you got headlights, injectors, spark coils, radio, fuel pumps, computer, possibly meth pump, possibly intercooler pump...people often neglect the electrical load and it is significant when you start adding a bunch of stuff.
Old Nov 23, 2015 | 05:39 PM
  #613
GRRR65GTO's Avatar
If you are wondering how to run a second set of wires into the tank they make bulk head fittings for wires in fuel tanks. I had one that came in the EZ efi kit for my blazer that I didnt use and it worked for me. I just made my own hot wire kit. I ran wires from where the factory relay goes (in your case run the wires to the factory relay while its still in the fuse fox) to a seperate 40 amp relay
Old Nov 23, 2015 | 06:12 PM
  #614
03sierraslt's Avatar
Where did that come from?
Old Nov 24, 2015 | 01:00 AM
  #615
Blown06's Avatar
8 Second Truck Club
Very important post.
  #616
Blown06's Avatar
8 Second Truck Club
The flow of the pumps will add together minus some losses due to how they are combined. For example, putting 2 pumps together in a T does not equal twice the output of a single pump with a straight connection.
Also, very important post.
Old Nov 24, 2015 | 10:12 AM
  #617
shootermwc's Avatar
Looks like maybe a Fragola electrical bulkhead? I'm thinking about doing the same thing to mine with the XFI controlling the pump. Instead of trying to figure out which factory pin and relay. Just run new, heavier gauge wire with a solid state relay.
Old Nov 24, 2015 | 11:18 AM
  #618
GMCtrk's Avatar
drill holes in bucket hat and seal with goop. Done.
Old Nov 24, 2015 | 12:35 PM
  #619
Vortec350ss's Avatar
Ive already done that. I will use those wires for the 450, and the factory power source for the 255.
Old Nov 30, 2015 | 06:38 PM
  #620
BlackGMC's Avatar
Resident Retard
So what is the latest on the beast?
