Spoolin's attempt to Spool...
#501
I think an out of cab and an in-cab are next on the list along with working out the bugs, hopefully I'll find the crossed wire in the tranny harness either today or tomorrow.
In my very first post those are Nitto 265/40/20
The new tires I have now that I bought for the competition last Friday are 275/35/20's. They look pretty small on my truck and lowered me about 2.5 inches. Wasn't planning on them making that much of a difference but the truck's got a whole new look to it with the new shoes.
#505
dam been back and i havent even got a call to come check it out , i see how it is .
sucks i had to miss the throwdown but things happen. ill have it ready by the winter time to get full advantage of the cold weather and make my goal with the upgrades i have planned.
give me a call before you get sent out again , we need to kick it .
#507
I should be up your way on the 9th (Thursday) maybe as I'm headed to Temecula to kick it with Lee at EFI Academy. I don't think I'll have my issues worked out by then but we'll see. We'll probably be around till after you get off work so I'll get a hold of ya and see if we can't stop by.
Thanks man!!
#509
9 Second Truck Club
Turbo sounds sweet!
Do you have all your grounds hiched up correctly? There should be 3 on the engine. 2 in back of the intake, and one behind the ps pump. If those are off or compromised wierd **** will happen. Also you need good grounds all around the truck. Chassis to engine, chassis to body, engine to body etc.
#510
I can guarantee you I have none on the back of the intake. I have most of the grounds on the block hooked up and I would imagine most of the cab to frame ones as well. I'll go ahead and do that today, I'll just add random grounds if that's cool.
So unless it's a bad thing to have extra grounds, I'll add a ground from...
1) Frame to body
2) intake to block
3) Block to frame
They are probably redundant but what the hell, any other ones you think might be good too?
1) Frame to body
2) intake to block
3) Block to frame
