Slow and getting slower
Old Apr 9, 2012 | 10:59 PM
  #791
Atomic's Avatar
I have a gauge for that
I have a ladder rack sitting in my garage, just havent put it on yet
Old Apr 10, 2012 | 03:37 PM
  #792
Atomic's Avatar
Got my filter situated. The 5.5" is a freaking cave next to a 4". I wonder if this filter isnt a restriction, I will find out on the dyno eventually, but for now I feel better having an air filter
Also ordered some 2" DJM shackles.
Old Apr 10, 2012 | 05:26 PM
  #793
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Richard, that filter set up is nice & clean. looks like it was meant to be.
Edit: oh, & good choice on the shackles
Old Apr 10, 2012 | 08:13 PM
  #794
Atomic's Avatar
Went to metal scrap yard and had the truck weighed with me in it and a full tank and its right at 5050lb. A good 500lb heavier than what I wanted, but a lot of that is the 80e and 14b. That also means im making 500+ to the ground with low boost and low timing.
Also discovered my front diff actuator is broken. Tcase engages the front shaft fine but the axle doesnt engage.
Old Apr 10, 2012 | 09:09 PM
  #795
JoeyGC5's Avatar
What/who's turbo blanket is that?
Old Apr 10, 2012 | 09:16 PM
  #796
1FastBrick's Avatar
Custm2500's Rude Friend
Empty the tank cause it won't take much to get you down the quarter... You got a turbo so you don't need filter... Just put some screen in front of it... And last but not least, next time take a dump before you weigh in
Just messing with you man, glad to see you got it running properly.
Maybe I need to work on lightened housing for you...
Old Apr 10, 2012 | 10:03 PM
  #797
Atomic's Avatar
It one of those $50 blankets off ebay...its a little small but seems to work well. I cant justify spending 3 times as much when I can have 95% of the performance in this guy.
I dont plan on ever letting the tank go below half full. I really think that contributed to my issues on my 410; fuel starvation when the tank was near empty. I distinctly remember going WOT and it misfiring because of no fuel.
I dont really care about weight on the rear axle, its the best place to have it and I dont seem to have a problem getting good traction. Hell the cover I have weighs 25lbs by itself
Old Apr 10, 2012 | 10:29 PM
  #798
smokeshow's Avatar
Mod with training wheels
Don't spent the extra on the expensive ones...ebay blankets work fine. They die at about the same rate from what I have seen.
Old Apr 11, 2012 | 06:32 AM
  #799
custm2500's Avatar
Ph.D. in HUBRIS
If this is a solid concern why not put a cell in the truck? I know you are trying to keep it on very stock apearing but with the money and time you have invested in getting a fast truck I would want every bit of insurance possible. A cell is going to give you that. I would think you could find a cell that is still fairly large and fit in the stock location. Then you still have all the sleeper and all of the safety of a sumped fuel tank. Just a thought.
Old Apr 11, 2012 | 08:21 AM
  #800
joeyc125's Avatar
11 Second Truck Club
A fix for the fuel starvation would be to extend the pickup of your second fuel pump, or both, toward the rear of the tank. You could use any semi rigid tubing curved to the rear. I don't know how your pumps look on the inlet side to attach, but I'm sure you could figure something out. I have my second pump fed from the bottom rear of the tank and have never had an issue even a little under 1/4 tank and hard 4wd launches.
