shakenfake's Sierra SLT LBZ thread (BORING)
#421
New bulbs didn’t fix it. Super weird. I think the lines on the Denali housing are actually causing this.
I won’t worry about it. I don’t think it is distracting or blinding oncoming drivers.
Also leaking oil out of intercooler tubes on passenger side. Just a drop here and there. Going to clean it out and replace o-rings when I receive them.
Well, that's a bummer on the lights. Have you checked to see if maybe you have a crack or something on the housing? Maybe just swap the old bulbs if you have them as well?
#422
Housing and projector look fine. Just is one of those lines that the stock housing has running across it.
I can’t find the old bulbs. I swear I kept the good one but no idea where it went…
#423
not sure what lines you're seeing in the light pattern, but my early-year factory Denali projectors had plastic reflector bowls which tended to get spider cracks over the years. that started showing in my beam patterns after a while.
#425
Doing pcv work and realized I forgot to order the turbo mouthpiece plug…
Someone has been in here. Whoever removed the cold side last did not replace one of the o-rings, I don’t remember which side but I am pretty sure the intercooler side, which explains why I just seeped oil like nuts. Good thing I bought those o-rings as I went ahead and just replaced both of them.
Pulling the cold side tube wasn’t bad but it was not as easy as I thought it would be. Think it took me an hour with no knowledge going into it. Just a lot of wiggling and moving.
I should have just bought the HSP mouthpiece I wanted but I’m restraining myself. I hate capping stuff, drives me nuts.
#428
https://hspdiesel.com/hsp-vgt-intake...ax-lly-lbz-lmm
@silentbravo This is what I was looking at. I thought bronze chrome from Prismatic would look sweet but some say I should just go gloss black.
