shakenfake's Sierra SLT LBZ thread (BORING)
Old Nov 29, 2022 | 08:25 PM
  #171
shakenfake's Avatar
Shlumpt
5 Year Member
What in the old man repair is this?
Can't believe I never noticed that the first time. New battery cable coming this weekend.
You can barely see it but is that second wire coming off of it supposed to be on there? RockAuto doesn't show any grounds similar to that.
Old Nov 29, 2022 | 08:29 PM
  #172
1FastBrick's Avatar
Custm2500's Rude Friend
can't see a second wire
Old Nov 29, 2022 | 08:30 PM
  #173
shakenfake's Avatar
Shlumpt
5 Year Member
I'll take another pic hold on
Old Nov 29, 2022 | 08:35 PM
  #174
shakenfake's Avatar
Shlumpt
5 Year Member
Should be able to see @1FastBrick
Old Nov 29, 2022 | 09:15 PM
  #175
strutaeng's Avatar
5 Year Member
Haha. One of the battery posts on my Suburban is exactly like that! Bought it from older gentleman too. 😊
I just let it be. 🤷
Old Nov 29, 2022 | 10:05 PM
  #176
silentbravo's Avatar
5 Year Member
My truck has that exact same smaller ground wire crimped below the large one like that. Should be factory.
I thought you were talking about the bolt with nut, which is really funny because my dad just did that exact trick while putting a battery in my other truck haha.
Old Nov 29, 2022 | 11:01 PM
  #177
1FastBrick's Avatar
Talking
If that is the front left battery, That extra wire goes to the front of the core support mount on the frame under the front bumper. All The GMT800's are like that.
Why don't you see if that connection is bad at the battery first. You can buy the plastic cover and a new bolt if that's all you need.
Old Nov 29, 2022 | 11:11 PM
  #178
1FastBrick's Avatar
The left front battery ground connects here with another ground from the headlight harness. But that is just a temporary bolt from when I was trying to fix the issues with my doner.
Old Nov 30, 2022 | 12:26 AM
  #179
_zebra's Avatar
makes children cry
i initially had issues with that ground when i did my swap... sanded it down to get a better connection & grounding problem went away.
Old Nov 30, 2022 | 12:37 AM
  #180
5 Year Member
Unless the bare wires are corroded you probably don't need to replace it. For the ground side, it's almost better to remove the boot because corrosion builds up inside those boots and it's a lot easier to clean it with no boot, also easier to inspect the wire for corrosion. I put some liquid tape over the exposed wires on mine.
