Project Purple Frost - 2000 Silverado RCSB
Old Dec 17, 2023 | 06:36 PM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
Can't you adjust the shaft that connects to the box? or perhaps the box was not centered before installing the pitman arm?
Old Dec 17, 2023 | 07:55 PM
  #32
silentbravo's Avatar
5 Year Member
That's a 4 spline pitman isn't it? So if you move the pitman 90 degrees , basically clocking it over to where the splines line up again it should be 90 degrees?
You do need to check and see if the box is in it's centered position though.
Old Dec 21, 2023 | 06:44 PM
  #33
GoodManners's Avatar
Good info. Thanks
I rotated the steering shaft and attached it. Then straightened the wheels to the steering wheel by adjusting the tie rods.
Old Nov 24, 2024 | 06:26 PM
  #34
So I replaced the inner and outer tie rods on both sides. Plus I put in new upper control arms. It's going in tomorrow to the shop for alignment - so I'm hoping the steering is tighter.
I need some winter tires cause it's snowy outside.
And I scored a used hot water pressure washer - too bad it's too cold outside to use it. Can't wait for summer.
Old Nov 25, 2024 | 07:39 AM
  #35
wretched73's Avatar
Hot water pressure washer is a game changer.
I used one to strip the wax coating off my frame. It came off in one pass.
Old Nov 25, 2024 | 07:52 AM
  #36
strutaeng's Avatar
5 Year Member
Nice score on the hot pressure washer! 👍
I too have heard they work awesome.
Old Nov 26, 2024 | 11:15 AM
  #37
_zebra's Avatar
makes children cry
we had one when i detailed at the chevy dealer. worked magic.
Old Dec 5, 2024 | 09:16 AM
  #38
Steering is way tighter after replacing those parts and the alignment has fixed the cocked steering wheel which is nice.
I'm not sure of the direction for this project - I think this truck will stop being my daily driver if I can find another truck. Then I can work on it when I want.
Right now I'm trying to sort some trouble lights and other small issues. I'm going to post the PCM / trouble light issues in another post on this site. I've got HPtuners MPVI3 coming and can't wait to get into another hobby tuning my truck. lol
Also the cab is noisy as hell on the highway - like ridiculous so i'm going to try and solve that next.
GoodManners
20
Jul 19, 2023 09:44 PM
skyhighsami
Apr 21, 2023 06:56 AM
OrangeChevyII
Jan 3, 2012 08:39 PM
jimbobs92rs
Sep 19, 2010 10:27 PM
GMracer
Sep 20, 2008 07:03 AM
