Project Kermit
Old Sep 20, 2009 | 02:52 PM
  #791
Spoolin's Avatar
GFYS and STFU
Originally Posted by Wilde Racing
I believe someone had mentioned a 02 issue with your log...... BTW, I need some 0-2 sensors have any old ones you are not using ?
Originally Posted by Spoolin
With the help of a friend...Was also suggested to make sure that one of my O2 plugs didn't work itself loose.
I know you did you dingle-berry!! I checked them visually and they were good and was looking at a scan and the O2 readout on the far right of the screen (forgot the bank #) when you use the "gauges" table on HPT scan tool is flat dead and in the red. Usually that bar graph is going up and down with the O2 sensor's readings. I assume that's the passenger side sensor?
Also if you really need a couple O2's I can bring you some in October. Also have a stock Y-pipe to go along with it. That what you need?
First off I thought the Mail man was your daddy???
As far as the O2 sensor issue, Yes It will cause all the Problems you described. Think of the O2 sensor like a nose. It samples the spent exahust and tells the computer how its doing as far as timing and fuel are going. Let say you pull it out.
Now The computer is like your girl freind back when you were 16 or in your case your Boy freind... It saying Hello, am I doing it right???
The computer knows the engine is running becuase of the other sensors but It doesn't know if its running rich or lean becuase the 02 sensor is not functioning. The computer keeps trying to compensate by adjusting the timing and fuel mixture up and down....
Thank you for putting it so eloquently Joseph!!
Old Sep 20, 2009 | 03:08 PM
  #792
1FastBrick's Avatar
Custm2500's Rude Friend
Any time ***-a-saurace-rex!!!
Old Sep 20, 2009 | 03:32 PM
  #793
Spoolin's Avatar
GFYS and STFU
Come over and help me run some wires you douche...you know more about power wires in the harness than I do! With my luck I would tap into the windshield wiper fluid line thinking it was a hot lead!
Old Sep 20, 2009 | 07:07 PM
  #794
trever1t's Avatar
2nd fastest 5.3 ECSB
are you ready yet?
Old Sep 20, 2009 | 08:02 PM
  #795
Spoolin's Avatar
GFYS and STFU
My truck is faster on jack stands than yours is on juice on a cold October day!
Old Sep 20, 2009 | 08:10 PM
  #796
larsy87's Avatar
apple bottom jeans
faster to get ON the jackstands? you can prolly jack that thing in under 2 minutes...you should apply for nascar.
Old Sep 20, 2009 | 08:13 PM
  #797
Spoolin's Avatar
GFYS and STFU
Job application went in this morning!!
BTW...A General FYI here.
After talking with Tarrant from wilwood last Thursday, if brakes are allowed to sit too long on a shelf and not primed with brake fluid than the O-rings start to dry out and lose their elasticity and therefore do not allow the pistons to move in and out freely. I hope I don't have to do the same thing with the rears because they had been sitting on a shelf for 3 years although they had never been used prior to that so they were basically new in box when installed, unlike the fronts which I had previously put maybe 20,000 miles on them...
Old Sep 20, 2009 | 09:26 PM
  #798
1FastBrick's Avatar
The new ones were never exposed to fluid so I think you'll be ok... the should still have some sort of Oil on them from assembly. If they dried out or had an issue They issue would have shown up by now and probally started leaking...
The front ones on the other hand were left on a shelf. The problem with brake fluid Is its water soluible. It will absorbe water esspecially if the system is left open. Mileage has nothing to do with it.
Old Sep 20, 2009 | 10:20 PM
  #799
CHEVRACER83's Avatar
damn dude sorry ive been so busy just caught back up with this.... taht is nuts dude, taht looks awesome!!!
Old Sep 21, 2009 | 02:13 AM
  #800
Spoolin's Avatar
GFYS and STFU
SHANNON!!! Your alive!!
How was the market? You buy a skate board?
