Project Ive had superchargers along time and want a Turbo.
Old 07-21-2018, 03:37 PM
03sierraslt's Avatar
Default Project Ive had superchargers along time and want a Turbo.
Figured I would start a build thread at this point. Parts are still coming in but all is in motion. I am gonna run a Trick T6 setup. Stage 6 Hotside, and 4” race intercooler. Turbo is a Borg Billet S480 T6, 80/92 1.1 AR
I am gonna run a stock TBSS intake for now to help low end. I have a new cam coming as my current 230/242 115 was specd for my old TVS setup and a bit much for this setup and a turbo.
Rick@Trick has been great about helping me sort out a plan, coming from a TVS at high boost I wasn’t gonna be satisfied with a small turbo regardless of response. My choice was what I perceived as a happy medium as I plan for 20-22psi. This isn’t a daily driver, it’s a toy. I built the valvetrain in this motor to spin some rpm so I don’t want something that signs off at 6000rpm.
Much more to follow.
Attached Thumbnails Project Ive had superchargers along time and want a Turbo.-d5e21cf0-67f3-4b8c-8da4-843b1b5a5a5c.jpeg   Project Ive had superchargers along time and want a Turbo.-2cb59eff-91bc-406f-b642-1f4d4a7bfdf7.jpeg   Project Ive had superchargers along time and want a Turbo.-8e83330c-f931-4feb-af2e-81a8305862a1.jpeg   Project Ive had superchargers along time and want a Turbo.-86173979-fd6a-4cbf-a983-139b0060cd89.jpeg
Old 07-21-2018, 03:54 PM
Truck Sponsor
Wheatley's Avatar
Gonna be a nice build!!
Old 07-21-2018, 07:31 PM
Well it’s running NA on motor at the moment, back to DBW. Here is a quick idle and rev clip. Pretty responsive considering it’s still 100% on my last DBW 16psi tune. Lol.
I didn’t change a damn thing, just loaded the old OS And tune in.
Old 07-22-2018, 09:55 AM
SDjeff619's Avatar
Looking forward to seeing this build. What are the details of the block and heads if you don’t mind?
Old 07-22-2018, 04:52 PM
Build thread.
https://www.performancetrucks.net/fo...-stage-544782/
Short story.
TSP gen 4 Iron 370
Wiseco pistons
Callie’s Ultra Billet H beam rod
Callie’s Dragonslyer crank
Big Manton pushrods
Johnson link bar lifters
Tea Ported TFS 225 Heads , super alloy exh valves.
I forget the rest.
Old 07-22-2018, 07:02 PM
I have a gauge for that
Atomic's Avatar
Add a pressure sensor in the exhaust to monitor turbo drive pressure vs boost vs rpm. That will be very interesting.
Old 07-22-2018, 07:23 PM
I plan to. I was already talking with Rick about that. I am curious as well. I am gonna check numerous other things also. Just for informational knowledge. I did the same with my TVS. I am gonna get it up and running first, then start playing to gain info. I don’t plan to push it harder than 15-16psi this year. I need to convert to 3bar and finish doing my flex fuel conversion.
Old 07-22-2018, 07:37 PM
Atomic's Avatar
Well go ahead and drill/tap or weld in a bung for it before you install it. Its a lot easier to do now and just plug it until you are ready than add it later. I give it a month before you upgrade the turbo
Old 07-22-2018, 07:47 PM
To what? I have too much going on this year. It will be next year at the earlierst. Or over winter. Upgrade the turbo or go to a bigger AR?
Old 07-22-2018, 08:46 PM
SDjeff619's Avatar
What Comp ratio?
Quick Reply: Project Ive had superchargers along time and want a Turbo.
