Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Dec 9, 2006 | 10:12 PM
  #581
TurboGibbs's Avatar
Yeah the beer fridge. Where is it?
Old Dec 9, 2006 | 11:10 PM
  #582
kbracing96's Avatar
It's at your house
Old Dec 10, 2006 | 03:53 AM
  #583
GMC_DUDE's Avatar
Just a quick note to say thanks for the excellent posts, Grip. I myself am in the middle of a similar teardown and your photos and descriptions have been an invaluable aid. Thanks again and take care.
Old Dec 10, 2006 | 10:04 AM
  #584
moregrip's Avatar
what a rush!
Cool, your welcome bro, glad I can help
Old Dec 10, 2006 | 10:34 AM
  #585
moregrip's Avatar
what a rush!
An observation I have made form your pictures. It seems GM is really trying to standardize parts. Like you LS2 cam gear, the bolts for your valley cover are LS6 bolts, the LS2 rods and I would be willing to bet your pistons are the same they put in the LS2s. Guess it cuts costs to use the same rods and pistons in all the 4" bore engines even if the rods are a little more beefy(maybe expensive?). Wonder if your motor came with the LS6 oil pump?
there is probably some truth to this. The water pump is LS2 derived as it has the non replaceable rear cover and smaller bearing surface, the rods appear to be LS2, however I have not confirmed whether they are full floating or not, the pistons look like LQ4 pistons to me with the slight dish, not sure about the oil pump, Cam gears are LS2, that's pretty-much what I've observed so far
Old Dec 10, 2006 | 11:21 AM
  #586
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you shine a light down in the bore from the bottom I would think you could see the ring lock down there.
Old Dec 10, 2006 | 02:29 PM
  #587
moregrip's Avatar
what a rush!
FYI, this is what I used to prep the block:
Old Dec 10, 2006 | 03:31 PM
  #588
moregrip's Avatar
what a rush!
one down, seven to go
Old Dec 10, 2006 | 03:48 PM
  #589
Richard@WCCH's Avatar
FormerVendor
Good catch on the crank pulley. This freshen up should weed out all those issues. It looks like your timing to do this now is about right.
Richard
Old Dec 10, 2006 | 04:53 PM
  #590
moregrip's Avatar
what a rush!
Richard
there is some pretty decent carbon buildup as well, I guess Navy petrol isn't so good
I'm hoping the snout is ok
