Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1362
Originally Posted by 2005SSR6Speed
Looks great Bro, now I can make sure it all gets polished up real nice for you. I will drop it off on Tuesday.
#1364
I can't believe the tape held up to that chem strip. What'd you use Jasco?
Doesn't all the hardware have to come off for the polish? Looks great, and like said above you have done a meticulous job, well done!
#1365
I try to do everything the right way, at least what I consider to be the right way
the hardware will be fine because those bolts are getting replaced with ARP SS 12pts, in fact, the the whole blower/manifold/J-Tube/TB setup is getting them.
I used Aircraft Stripper, not as strong as I remember it being, but it got the job done just fine none-the-less.
#1366
parts are with Joe now, schwing!
something like this but with more wrinkles in the tires..........
http://prismphotos.com/gallery/showp...=16160&cat=452
Originally Posted by Brian@JPA
all you need to do now is figure out how to beat me
#1367
#1368
Originally Posted by TurboGibbs
If you get the *** end down you'll have better weight transfer.
#1370
some of the individual pcs that make up the mount:
holes drilled ready for rivets:
aluminum square stock mounted to the stock cross bar:
upper tranny cooler mount using the Magnuson Radix bracket and a piece of aluminum flat bar:
