Project $50 LS1
#34
thanks, I used the two center valley cover holes. I left the cover on, and used a longer 10.9 grade bolt set. 8mm x 1.25. I used two of the same bolts to pull 800-1000 pound cat motors out of a topkick, so I knew it would be ok for a little motor.
#35
nice..did you get any times dyno numbers out of this?
im doing a very similar setup on my extended cab, ls1 as well...i want to get more a less around figure of what she'll be putting down.
FormulaZR
09-14-2015 05:23 PM
