potato land build, 9's@140+ is the goal
#105
It's 1/2 NPT. But I would do a -12 drain that's just me eventhough mine seems to be okay with -10.
You can tap the pan just fine with it on but you will have a LOT of metal shavings sitting in the bottom of the pan. I feel they will just sit in the bottom and not cause a problem but I pulled my pan just because I didn't want the thought of all that metal in there.
#110
well thats good news, i was worried about getting it too hot and blowing it up since i believe its under pressure . so i just ordered the oil adapter for the feed from trick performance so no drilling/tapping there which is good news to me. so im thinking about running the return to the front of the pan right below the crank pulley , i looked around last night under the truck by the starter ,by the ac compressor and it just seemed like it was allot easier to get to the front of the pan with a drill then anywhere else . anybody have some pics they can post up of them returning the oil to this spot? you guys think it will be a good spot for the return ?
