7 Attachment(s)
alright, it's been a while but i made some progress with the 14bolt. here it is.
this is the 'starter kit' that por-15 has. it worked out pretty good since the can was just the right amount for the rear end. Attachment 144102 this is how potent their 'marine clean' is. this was only about 10 min after applying it. Attachment 144103 after applying their 'metal ready' product to it. Attachment 144104 after 2 coats of por-15 Attachment 144105 after 2 coats of top coat Attachment 144106 new bearings, seals, and backing plates on Attachment 144107 ta cover just sitting in place Attachment 144108 i still have to get the axle flanges machined down, or take a grinder to them. then find some help to get it swapped. |
I like the way the POR-15 sets in the pics. I ended up doing 6 coats with VHT chassis black paint and so far its holding up well. If your by yourself a tranny jack works decent for installation/removal.
Originally Posted by JoeyGC5
(Post 4757017)
as far as installation goes im just going to put the tires on it and roll it into place. |
Originally Posted by chevyrace47
(Post 4757035)
6 coats seems like a lot.
5 Attachment(s)
Here's the final prep and install of the 14 bolt. Its actually been in the truck since september, I've just been to busy with work to update this thread.
Axle flanges shaved down with a lathe. Attachment 144109 Brakes set up and ready Attachment 144110 The 10 bolt coming out Attachment 144111 I didn't have a free hand to take pics during the swap but it went as smooth as it could. I still need to cut the u-bolts. Attachment 144112 I ended up damaging the aluminum yoke trying to press the old u-joint out to swap the 1350 conversion joint in. My driveline guy said they couldn't weld a new yoke on the aluminum so i had to get a steel driveshaft made. Attachment 144113 Everything's been working great so far. I have a very slight vibration at about 75mph, not sure what it is right now. Speedometer is off a little due to the lower ratio, but I like having more low end. I still need to either swap the master cylinder or add a proportioning valve to be able to use the rear discs at their full potential. POR-15 is holding up pretty well, however the topcoat has scratched in a few places. The only thing I haven't figured out yet is how to convert the parking brake cables. Probly just need to make a trip to the junk yard. |
Looks good under there. Glad to see you got it finished!
Your probally better off not haveing the aluminum D-Shaft. How ever they can be repaired maybe the shop you went to is not capable of it but others are. I hope its not the new shaft that is causing the vibration. |
(Post 4804983)
(Post 4804995)
I figured they could be repaired, but I'm over it. The new driveshaft was balanced at 9k rpms. Or so the guy said. I didn't change the pinion or carrier bearings so the vibration could very well be from either of those. Any suggestions on narrowing down whats causing it?
Also Deppends on how the shaft was ballanced. Im not an expert but I know they have different ways to balance them. 1 way gets it nearly perfect. The other gets it in the ball park but deppending on the application you could detect a small amount of vibration. |
(Post 4804998)
The Joints could cause it esspecially if you damaged it while trying to press them out.
Ever follow up on this??? Do you still have your old Aluminum DS???
