obs 14 bolt semi-float swap
5 Attachment(s)
i finally got some work done on the 14 bolt and figured i'd post pics of what i have so far.
it took almost 4 hours and 4 different drill attachments to get to this Attachment 144070 the brake brackets i got from fastbrick and had a friend weld Attachment 144071 Attachment 144072 these are what i used to get it close to bare metal Attachment 144073 brake hardware Attachment 144074 POR 15 is on the way, then modify the brake lines. get a conversion u-joint for now and bolt it in. |
looking good so far.
How far from the end of the axle tube are the flanges welded?
Originally Posted by Atomic
(Post 4730340)
I as well as Atomic and some others know how much of a pain this swap is. Looking good though. Are you going to trim the old backing plate flange off?
Not planning on it. I'm to lazy.
iv been reading some of the threads and just thought about it. if i find a 68" axle with my same gear set, i could just weld on some spring perches and bolt it up right?
the mods that you and atomic are doing are simply if you WANT to run disks right? my NNBS already has drums in the rear. |
Yes. That would work. But if you could find one from the same body style you wouldn't have to worry about the spring perches. You'll also have to use either a conversion u-joint or change the yoke on your driveshaft.
Wasn't it 2 and 7/8 from Wheel mounting surface of axle flange to face of backing plate bracket??? As long as you mocked it up properly should be ok.
(Post 4734109)
