Oakley's History Lesson and Build Thread
Old Feb 14, 2014 | 07:55 PM
  #411
GMCtrk's Avatar
I like the look of those Cragar's. If they actually tucked I'd run a set of the 15s.
Honestly, if you get it to hook up, you should put that thing into the 11s
Old Feb 14, 2014 | 07:59 PM
  #412
oakley6575's Avatar
I'm having cragar make a set of steel wheels that will tuck. Just having a hard time getting one of there vendors to order them for me. They claim the rear 15x10 wheels weigh 34 lbs and I can order them for $100 a wheel I'll definitely do that first before I go with bogarts
Old Feb 14, 2014 | 08:28 PM
  #413
oakley6575's Avatar
FML. Same bullshit as last time. Won't shift out of first gear. I'll upload a log file later
Old Feb 14, 2014 | 08:38 PM
  #414
oakley6575's Avatar
This run was better but I still had to let all the way out at the top if first.
  #415
GMCtrk's Avatar
That is heavy, heavy. That may even be more than my factory 20x8.5s.
My stock steel 16x6 weighed 25-26 lbs.
I'm not sure about Bogarts, but the Race Star 15s supposedly weigh 17 lbs. That's 17 lbs less, 34 lbs of rotational weight for 2 wheels. Even assuming 1 lb rotational weight = 4 lbs static weight, thats a theoretic 136 lbs weight reduction. But it may be even more than that, maybe worth up to 2 tenths at the 1/4 mile. $200 for Cragar's vs $550 for Racestars and $800 for Bogarts. Also, the Cragars wont look as good.
Old Feb 14, 2014 | 08:41 PM
  #416
GMCtrk's Avatar
Crap man, if you're having to lift at the top of 1st, you could be looking at a whole second there! I've got my shifts set to 4600 to get it to **** where I want.
Old Feb 14, 2014 | 09:48 PM
  #417
oakley6575's Avatar
I have it set at 5000rpm right now. I'll move it down to 4600 and see what it does. I'd be impressed if I get into the 11's tonight. That 2.0 60' is about the best I can do with my 3.42. Will probably go to 3.90 soon
Old Feb 14, 2014 | 10:38 PM
  #418
69Camaro427's Avatar
I like 12.3 vs 12.99 regardless
Old Feb 14, 2014 | 11:01 PM
  #419
oakley6575's Avatar
So the last run I set the shift point in first super low and it shifted at 5800. So I'll raise it back up a touch. I blew the tires off at the line. For a remarkable 2.5 60'. went 13.0 at 114mph.
Old Feb 15, 2014 | 06:03 PM
  #420
Will you have a harder time hooking with 3.90s? Did you notice your rpm in 3rd when crossing?
