Not a truck, not a LS engine, but weighs as much as a truck, "69 Twin TurboCharger"
Old Jan 15, 2012 | 10:36 PM
  #101
Wilde Racing's Avatar
How do I change this text
Originally Posted by 01GMC5.3
very nice sir ! how does the piece you made attach to the turbo ?
It uses a ring very much like a piston ring and a spring to seal. I will also use a piece of strap to hold the pipe in the turbo housing. Once I get the car running and run out of turbos, I'll replace this section of the down pipe with a V-band...
Old Jan 15, 2012 | 11:23 PM
  #102
53RUSSELL's Avatar
Looking good man.
Old Jan 16, 2012 | 11:49 AM
  #103
1FastBrick's Avatar
Custm2500's Rude Friend
Some progress is better then no progress....
Old Jan 16, 2012 | 10:09 PM
  #104
Originally Posted by 53RUSSELL
Looking good man.
Thanks!
Yea, here is a little more.
I managed to sneak out to the garage for a few more hours this afternoon. I need to attach my tone ring to the crank, I bought a 440source aluminum crank pulley but it is too thin to drill and tap this is the best solution I could come up. Basically I will machine a washer that will have three bolts that bolt from the inside of the pulley, then I can drill and tap the "washer" for the ring.
I started out with some left over stuff from the accy. bracket, I wanted to save as much as I could so I used the rotatory table to cut it out.
As you can see, I'm no damn machinist....
Test fit, and then rough cut it with the band saw..
Thinning it up a bit.
Chuck it in the lathe and spend an hour or two making it round and adding a taper..
Pretty good I think, just need a bit more out for the taper, then I need to drill and tap all the holes.
Here is what it will look like once it is finished.
Old Jan 16, 2012 | 10:23 PM
  #105
1FastBrick's Avatar
LOL. Well at least you have some tools to make it look professional.
Any chance you have some sort of CAD drawing program???
Old Feb 1, 2012 | 09:05 PM
  #106
Thanks, no CAD stuff not that I could do much with it I have Solid Works at work and I SUCK at it! All of my drawings are designed and tested in my head usually late at night while laying in bed.....
I managed to duplicate the exhaust fitting and I finished up the pulley mounty thinggy....
Next up on the never ending list.... Finish accessory brackets including power steering mount, tack down pipes including gate dumps, route turbo drains, mock and tack all EGT bosses. Once all of that is done the engine is coming back out and I can start wrapping up the turbo side of this project....
Old Feb 3, 2012 | 10:16 PM
  #107
01GMC5.3's Avatar
if I had any of those tool I could be dangerous if I knew how to turn them on
Old Feb 3, 2012 | 10:33 PM
  #108
BlackGMC's Avatar
Resident Retard
Damn you have some talent!!!! Working those machines like that the way you do is awesome. I am really jealous
Old Feb 5, 2012 | 08:27 PM
  #109
1FastBrick's Avatar
Were did you get the reluctor wheel from??? are you going to run a mega squirt set up???
Old Mar 23, 2012 | 08:53 PM
  #110
E-bay, and yes. I'll be using Mega, more on that later..
Well I've tried to not update as much and hold off until I actually make some progress.. Turns out I cant wait.....
I got a little more done on the power steering pump bracket but I hate the way it is turning out so I've tried to forget about it for a while....
I did however acquire a bit of magnesium in the shape of this...... Anyone have a lighter?
Exhaust made it this far...
Yes that is the waste gate dump...
I wanted Disc brakes for the car and as I'm broke I thought this idea might work out. The Hub was "removed" using a 20-ton press, the rotors and calipers are off a 2010 GT I still need to turn the hubs down slightly and make a caliper mount but other wise I thing it will work out well (and cheap).....
