My ongoing project
Old May 23, 2010 | 11:02 PM
  #121
Black'Rado's Avatar
that would be awsome if you dont mind.
the hsw microedge manual says to get the tps sensor wire is dark blue at pcm pin 24 red conector.
i would assume that i could also get the same wire at the tps sensor on the throttle body?
and the rpm wire is white at pcm pin 10. but cant i tap a wire on a coil or injector?
Old May 28, 2010 | 09:00 PM
  #122
Black'Rado's Avatar
Got my cam and HD2 shift kit in yesterday.
its a comp 220/220 .581/.581 112 LSA
same as tsp220
got to order valvesprings and pushrods now.
and a set of tires.....thinking either mickey thompson et street radials or hoosie quick time slicks.
i want something i can bolt on for the weekend and put a fair amount of miles on them. there going to go on my stock 16's.
any opinions?
Old May 31, 2010 | 09:56 AM
  #123
RedHotRodTruck's Avatar
I say go with the Mickey Thompsons...Neither will give you really good street miles.
Old May 31, 2010 | 11:09 AM
  #124
Black'Rado's Avatar
thats what i was thinking, i think they will do ok if i want to bolt em on for the weekend and put like 40-60 miles on them, and maybe a few mexico trips!
Old May 31, 2010 | 02:48 PM
  #125
When are you doing the cam swap? if you need a hand let me know.
Old May 31, 2010 | 03:25 PM
  #126
Black'Rado's Avatar
i need springs and pushrods still, but hopefully in like 2 weeks or so i will be ready.
Old Jun 7, 2010 | 07:44 PM
  #127
Black'Rado's Avatar
springs and pushrods should be here anyday now......oh yea also got some mickey thompson et steret radials 255/50r16s
im debating if i should go ahead and pull the heads to have them milled or order the scoggin dickey valve spring tool.....price difference isnt much.
also ordering the cam swap gasket kit and balancer bolt tonight.
Old Jun 7, 2010 | 11:00 PM
  #128
Black'Rado's Avatar
well went ahead and ordered a cam swap gasket kit and scoggin dickey valve spring tool.
after cam swap and tires are on.....im going to test out the juice!!!
Old Jun 8, 2010 | 06:17 PM
  #129
Black'Rado's Avatar
got the springs and pushrods in today....
Old Jun 9, 2010 | 09:16 AM
  #130
meangreenburban's Avatar
Trucks looks freaking sweet, awesome to follow it from stock to what you have got it at. Nice cam you picked as well
