My large frame front mount project with two videos
Old Mar 28, 2009 | 12:40 PM
  #311
fastlt1's Avatar
12 Second Club
Throw some slicks on that beast and take it to the track. I'd love to see it run with traction.
Old Mar 28, 2009 | 12:45 PM
  #312
Wilde Racing's Avatar
How do I change this text
Originally Posted by MikeGyver
is that whistle noise the reason no deer ran out in front of you in the video/
LOL, that would be useful at the track....
Originally Posted by 95 bright teal
Holy ****!
That is Fantastic!
Very nice build. So what are your plans for traction?
Four wheel drive, front limiters and some 305 wide tires...
Thanks guys... I need a much larger gate, and more injectors... I called Jose at Forced inductions, he told me even if I would have installed the 38mm gate without the divider, it still would be too small...
The rattling noise is a bunch of wrenches I threw in the front of the truck to take back to work...
Old Mar 28, 2009 | 03:06 PM
  #313
fastlt1's Avatar
12 Second Club
How does your turbo compare to T-76?
Old Mar 28, 2009 | 05:28 PM
  #314
It spools slower if I make it down shift, but if I just roll the throttle on it spools pretty fast. The power has came up a ton. I plan on hooking up the back pressure gauge, that will tell the whole story
Old Mar 28, 2009 | 05:41 PM
  #315
kbracing96's Avatar
How much boost are you trying to run, is it boost creeping a lot? How does it boost from a dead stop?
Old Mar 28, 2009 | 06:41 PM
  #316
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Take the damn tools out of the truck!!!!
Old Mar 28, 2009 | 06:45 PM
  #317
stock48's Avatar
9 Second Truck Club
Are you still running a stock verter? How does it launch in 4wd?
Old Mar 28, 2009 | 07:02 PM
  #318
Holds boost until 4500ish rpm then goes over I've hit 13psi with the 6 psi spring..
havnt done a dead stop pull yet... too scared..
Yes, stock Converter. It really over boosts if I actually load up the turbo.. so no 4wheel drive...
Old Mar 28, 2009 | 07:37 PM
  #319
stock48's Avatar
9 Second Truck Club
What's wrong with that? Make 16psi low boost, and 26 high boost.
Old Mar 28, 2009 | 07:39 PM
  #320
dewmanshu's Avatar
Moderately Differentiated
Stellar. Freaking stellar!
