My large frame front mount project with two videos
Old Mar 10, 2009 | 10:00 PM
  #231
MikeGyver's Avatar
Why would an oil cooler have a bypass? Is it thermostatic?
Oh, I just found your other thread.
Last edited by MikeGyver; Mar 10, 2009 at 10:26 PM. Reason: Oh, I just found your other thread.
Old Mar 10, 2009 | 10:50 PM
  #232
OnyxSilveradoSS's Avatar
+1 for the oil flow chart.
Old Mar 10, 2009 | 10:51 PM
  #233
GMCtrk's Avatar
This is truly going to be "wilde"
Old Mar 10, 2009 | 10:58 PM
  #234
Nevada79's Avatar
The oil cooler bypass valve is to block off flow through the cooler when the engine is cold. It acts like a thermostat. The engine oil heats up quicker when the oil isn't circulating through the cooler. The valve will help the engine maintain a constant oil temp.
I would leave the bypass valve alone and grab your oil supply from somewhere else. Does it really matter if the oil is a little cooler before it gets to the turbo. It's like taking a cold bath before going to the bunny ranch, your going to hell anyways so what difference does it make what temp you were before you got there.
Old Mar 11, 2009 | 04:37 AM
  #235
Wilde Racing's Avatar
How do I change this text
LMFAO, nice dude...
After a long talk on the phone, everything will be left were I had planed. The oil cooler bypass installed, and the turbo oil supply tapped after the cooler.... I did get a bit more done tonight and it is now 2:37am, I'm going to be even more worthless at work than usual.
The anaconda down pipe...
I got a lot of the wiring done, as well as most of the vacuum/boost controller lines done.
Still need to....
Finish cold side
mount a air filter
locate and mount a coolant res.
install heater hoses
finish oil cooler lines
install turbo drain
install turbo supply
finish wiring crap
reinstall drivers seat
I'm sure there is more.........
Old Mar 11, 2009 | 07:39 AM
  #236
built408's Avatar
turned out nice, good job
Old Mar 11, 2009 | 09:24 AM
  #237
silver-mod-o's Avatar
Hunt&Fisherator
I forsee transfercase chain slack in your future
Looks massive bro, can't wait to see the startup vid, what muffler did you end up with?
Old Mar 11, 2009 | 05:18 PM
  #238
Thanks guys...
As far as the muffler I'd rather not say....
It is off a dodge cummins
I hope it will be up and running, I wont be working on this weekend, so hopfully next week some time...
Old Mar 12, 2009 | 10:30 AM
  #239
Hunt&Fisherator
Well, everything else in the kit is big enough for a Peterbuilt, so might as well have a diesel muffler in there too, might sound similar
New name for Dustys truck: "Project log truck"
Old Mar 12, 2009 | 10:53 AM
  #240
Phantom's Avatar
11 Second Club
Nice work man. Can wait to get started on mine
