Mizz SS
#61
You stated the belt was gone, but do you know if the belt broke, shredded or just came off? From your earlier incident, seems you have an alignment or tensioner issue in which a stronger belt of same length likely will not fix. However a shorter belt could help with a tensioner issue to keep the belt on. Stronger belt is needed if you are breaking belts.
#62
The first time i popped the belt it just dumped off. I could see it had skipped ribs. This last time it was completely gone, saw it on the road ripped in half so not sure if it ripped after it fell off, or if that was the main cause. The alignment, to me, looks all good from everything i can see.
#63
