The last upgrade
Old 04-05-2011, 01:14 PM
  #41
I have a gauge for that
Atomic's Avatar
Originally Posted by MikeGyver
Well then you should have covered the engine block in flame retarding fabric to match.
x2
I should have anyway
Old 04-05-2011, 03:51 PM
  #42
11 sec. Truck Mod
TIM Z's Avatar
I like the blue block,looks good.
I'd like to see the valve covers on installed.
Old 04-06-2011, 02:03 AM
  #43
Mod with training wheels
smokeshow's Avatar
I'll have to get some pics of the valve covers this weekend. My camera is at a friends house. Truck feels way stronger on the bottom end. Top end is about the same as the 5.3 with timing and meth, maybe a bit stronger. Should be fun with another 4° of timing
Old 04-06-2011, 01:39 PM
  #44
14 Second Truck Club
double047's Avatar
Looking good, keep the pics coming.
Old 04-06-2011, 05:05 PM
  #45
Nicksilverado's Avatar
Nice!
Old 04-07-2011, 09:43 PM
  #46
99ta's Avatar
Which turbo did you end up with? Still says S475 in sig.
Old 04-09-2011, 12:41 AM
  #47
smokeshow's Avatar
Just put the S465 on it. That's how it's going to stay. Those pics show the size comparison between the two, 1.32AR exhaust housing with a 96mm turbine exducer on the 75, and a 1.10AR with an 83mm exducer on the 65. The 65 makes boost way sooner. I can actually roll into it in OD and almost get full boost Also a pic of the near-hidden valve covers. Wiring could use a little tidying-up, and it would look good with a coilpack relocate...we'll see.
I did lose about 2psi of boost, presumably because the exhaust side is smaller on the 65. Only gets 8psi on a 12psi spring I'm going to check in the morning to verify the quick spool isn't getting hung up. If it isn't, I may just have to swap in the lighter spring and pull the boost reference off of the WG. Maybe see about 11psi then.
Old 04-09-2011, 09:33 PM
  #48
slowlsx's Avatar
im glad the turbo worked out for ya mann, my truck is going together next week so we shall see how it works out with your turbo!
weird tho, when i had the 475 and went to the 465 i gained 5 psi? went from 10 to 15psi.. wierd?
Old 04-10-2011, 01:53 AM
  #49
smokeshow's Avatar
What size wastegate were you running?
Old 04-10-2011, 01:31 PM
  #50
Atomic's Avatar
Wait, when did you get a new turbo?
Quick Reply: The last upgrade
