Jake's '05 Rcsb s488 4l80 build
#264
Truck Sponsor
Keep in mind a
Vband clamp chews up more room.
A 4" pipe will need around 6" clearance all the way around.
Also when you do. Use the pipe as alignment. You should have a small amount of tubing sticking out say 1/4" or 1/2 the thickness of 1 flange.
That way the other side will slip up and on and stay and be aligned properly.
#266
well...truck is still getting painted slowly but surely. I decided to order some et street radials 295/65/15 today. I'm going to be doing the corbeau seats with atomics brackets and also adding some type of roll cage. I wanna keep the truck as street as possible (didnt want 2 bars out the back window) but with a good safety aspect. Other than that just need to get the bed back on the truck and get the driveshaft. Motor cranks right up. 55 psi oil at idle. Cant wait to drive this thing.
Paint is 040 toyota super white. The door is not painted yet. The back of the cab is.
