Jack's 2008 Silverado build
Old Sep 2, 2021 | 08:10 PM
  #21
settlemoore's Avatar
if it aint leaking then send it, i've seen worse
Old Sep 3, 2021 | 12:52 PM
  #22
terravast4's Avatar
Originally Posted by Jack1181
Thanks!
Also, for anyone that knows a bit about ac stuff. I have a small kink in my ac line that you can see in that last picture. Not too bad. Will that cause any issues?
that kink may cause a restriction that can affect the freon flow but if its cooling fine shouldnt be an issue.
Old Sep 4, 2021 | 03:08 AM
  #23
1BRAVO1's Avatar
Awesome and very thorough thread.
I really enjoyed the pics and the explanations.
Great job, great looking truck.
It makes it even that much better to know it was your dad's.
Old Sep 5, 2021 | 09:10 PM
  #24
Jack1181's Avatar
Everything is pretty much finished, fuel system was finished yesterday. Didn't get any pictures minus the sump
I couldn't use my 044 bracket I made, unfortunately had no where to mount it. I just used the ebay mount.
-8 from the tank to inlet on pump, -6 up to the tee into the factory hard line.
That's how its going to stay. I really want to wire tuck, but I don't have the time and patience for it
I powder coated and added amazon catch can that matches the turbo and coolant overflow. -10 from oil cap to top port, bottom to drivers cover.
Now I'm just waiting on a new battery tray. Although the more I look at that ac line, I really want to make a new one.
Old Sep 5, 2021 | 10:19 PM
  #25
1BRAVO1's Avatar
Looking good!!
Old Sep 9, 2021 | 05:33 AM
  #26
Superman09's Avatar
Truck Sponsor
Great write up and photos, looks awesome! Thanks again for the support and glad you like the new V4 kit!
Jon
Old Dec 1, 2021 | 07:49 AM
  #27
Jack1181's Avatar
Kinda forgot to update this
Truck is somewhat finished. Still needs some work, but its presentable atleast. Truck made a touch under 400 rwhp on the dyno.. Thats with shitty fuel, a very very very safe tune and about 5lbs since I'm still on the 4l60e. At the time I wasn't ready to go full bore yet since I needed the truck and the trans to hold a little longer.
Here are some finished pics and how the truck sits now. Currently finishing the 80e and hope to have that in early next year.
Also blew a trans cooler line and puked all the fluid out onto the highway. Swapped lines and refilled and the 4l60e still isn't cooked. Is definitely hurt from before, because I admittedly have been running it hard
Old Dec 1, 2021 | 07:55 AM
  #28
shakenfake's Avatar
Shlumpt
5 Year Member
Boo this man, still running a 4L60 under boost what is wrong with you!
Old Dec 1, 2021 | 07:57 AM
  #29
Jack1181's Avatar
You must've missed the part where I said the 80e is almost finished and should be in by spring
Its been 2 months with the turbo and the 4l60 lmao
Old Dec 1, 2021 | 07:58 AM
  #30
shakenfake's Avatar
Shlumpt
5 Year Member
Boooooooooo we want all at once!!!!
I'm just ****** with you truck looks good. I think I remember you have an upgraded trans cooler right? Did you change lines when you did that too or no?
