Also, for anyone that knows a bit about ac stuff. I have a small kink in my ac line that you can see in that last picture. Not too bad. Will that cause any issues?
that kink may cause a restriction that can affect the freon flow but if its cooling fine shouldnt be an issue.
Truck is somewhat finished. Still needs some work, but its presentable atleast. Truck made a touch under 400 rwhp on the dyno.. Thats with shitty fuel, a very very very safe tune and about 5lbs since I'm still on the 4l60e. At the time I wasn't ready to go full bore yet since I needed the truck and the trans to hold a little longer.
Here are some finished pics and how the truck sits now. Currently finishing the 80e and hope to have that in early next year.
Also blew a trans cooler line and puked all the fluid out onto the highway. Swapped lines and refilled and the 4l60e still isn't cooked. Is definitely hurt from before, because I admittedly have been running it hard
I'm just ****** with you truck looks good. I think I remember you have an upgraded trans cooler right? Did you change lines when you did that too or no?
