I can't fabricate?
Old Feb 17, 2011 | 01:58 PM
  #21
outlawz2004's Avatar
Your sig pic shows the body lines lined up on the cab and bed, was that taken 240,00 miles ago?
In this pic the line at the bottom lines up, but the gap is way off, it opens way up at the top and close at the bottom like its twisted or not square on the frame. If the cab mounts were bad, the line at the bottom wouldnt line up, the cab would be lower.
Old Feb 17, 2011 | 05:51 PM
  #22
shawnss's Avatar
wow what chicken took a **** on that stuff???
Just kidding man. its better than i could do. i have welded but only thin metals for autobody stuff. you have to start somewhere. atleast your giving it a shot. better than most would do.
Old Feb 17, 2011 | 05:56 PM
  #23
00ChevyScott's Avatar
Wearin' da big hat
I just fabricated this.
Old Feb 17, 2011 | 06:03 PM
  #24
_zebra's Avatar
makes children cry
Old Feb 17, 2011 | 06:38 PM
  #25
Beatdown Z's Avatar
Laid Back
I'm not the smack-talking type, so I'm just going to tell you to spend a bit more time grinding the metal clean before you weld. It will really help your welds turn out a lot better.
Old Feb 17, 2011 | 07:32 PM
  #26
Interesting read on this link, sounds very similar to whats happening now.
http://www.fullsizechevy.com/forum/a.../t-348057.html
Best part of the whole thread:
Custm2500:
Plus for me fabrication is much cooler than bolt on. I don't remember who it is but someone has in there sig. "Bolt ons are for beginners."
poboychevy:
there is absolutely nothing you did that i would consider "fabrication". you hacked off a bracket and boogered it back to the frame. and as for the bolt ons are for beginners.....you sir are a "beginner" and should respect the saftey of others and yourself. i have seen alot of hacks back in the day when all there was was mazdas, toys, and nissans rollin and what you did is a hack.
Old Feb 17, 2011 | 07:37 PM
  #27
BlackGMC's Avatar
Resident Retard
Man yall cut the guy some slack...
Old Feb 17, 2011 | 07:38 PM
  #28
smokeshow's Avatar
Mod with training wheels
I'd leave aircraft to the professionals, Scott.
Old Feb 17, 2011 | 07:52 PM
  #29
Your probably right, but when he started this thread he put it open for discussion.Guess I am just going to sit back and wait for results of the throttle body.
Old Feb 17, 2011 | 07:56 PM
  #30
Mangled03gmc's Avatar
Baltimore Whore
Agreed on both.. Those welds are not totally hateful, but do need work.. None the less I just think we are all used to seeing really clean jobs.. If it works for ya, go with it.. Jus saying
