Graeme's Daily Driver 2003 4x4 Build
Old May 11, 2016 | 07:54 AM
  #321
GM1697's Avatar
Originally Posted by Atomic
I wasnt planning on pulling any until I got over 100
going ***** deep there huh
Old May 11, 2016 | 07:57 AM
  #322
03sierraslt's Avatar
Run good enough fuel with the nitrous and do it. Ill run a stand alone cell for my fuel side when I do nitrous just for that reason.
Old May 11, 2016 | 08:36 AM
  #323
Atomic's Avatar
I have a gauge for that
Hence the methanol
Old May 11, 2016 | 09:54 AM
  #324
Vortec350ss's Avatar
It was literally the first time it had ever been sprayed. Kind of a trial and error type thing while at the track.
Old May 11, 2016 | 10:27 AM
  #325
GM1697's Avatar
This is true, we hadn't verified my IAT trick either, so we needed some sort of timing retard to see if it was working
Old May 11, 2016 | 11:37 AM
  #326
Whats your IAT trick? You spraying pre iat and having it pull timing from the cold rather then add it?
Old May 11, 2016 | 12:48 PM
  #327
There is a relay in the sensor. When the nitrous hits the kit also sends a surge of power to the sensor and makes the PCM think IAT's dropped to -40. in the -40 column we took out 3*.
It's not something we could use boosted... or at least not something I would want to do boosted in case there is some sort of IAT spike we need to be mindful of.
Old May 11, 2016 | 12:54 PM
  #328
Atomic's Avatar
Kind of. When the nitrous solenoid is activated, that same signal activates the IAT trick relay, which essentially unplugs the IAT sensor. Because there is no signal, the PCM defaults to the lowest column (no signal is the same as 0v) which is -40F.
Old May 11, 2016 | 06:10 PM
  #329
GM1697's Avatar
yuppp what they said
Old May 11, 2016 | 08:40 PM
  #330
silver-mod-o's Avatar
Hunt&Fisherator
I've heard of that being done before and it seems to work very well, as long as the relay doesn't fail
