Fitting 15
Old Mar 31, 2017 | 11:44 AM
Jasinto78's Avatar
Default Fitting 15
What's up guys thanks in advance for the help,
I have a 2004 GMC Sierra 1500 ext cab
I have disc brakes and can't go smaller than a 16 inch rim, I want to fit 15 inch. is there a way besides going drum system to fit 15???? Maybe buying a different disc system?? Thanks again
Old Mar 31, 2017 | 02:06 PM
2KRedSilverado's Avatar
Grind grind grind away pal, switch to the s10 caliper.
Use the search tool, plenty of threads on what was done to accomplish what you are wanting.
Old Mar 31, 2017 | 04:17 PM
Jasinto78's Avatar
That's what I don't want to do grind, I'll try that s10 calipers maybe I grind less?? Thank you
Old Mar 31, 2017 | 05:36 PM
lycominghunter's Avatar
PT.net Member Oakley6575 1320 wheels both make brackets that utilize a different caliper and rotor to allow you to run 15in wheels.
For Oakley's info, see post titled "Disc Brake Brackets for 15" Wheel Conversion" in the Member Made Tools & Parts Classified Section of the forum.
Old Mar 31, 2017 | 07:27 PM
Jasinto78's Avatar
Thanks man I'll check it out
