Fab 9 and 4 link going in
#22
i hope your place knows what its doing and you dont go through what i did with my 96. i did a ladder bar coilover set up and my truck hooks worse! no weight tranfer, wrong coils were picked, panhard bar put in on a angle and between that and the bars it binds up. my rear end is 1.5 inchs farther back then it was before. my pinion angle is insanely stupid, the angle on the bar is retarded. its benn a nightmare. im fixing to redo it in the next month or so. with wrinkle walls and a 120lb spring its helped it a lot but im gonna half to redo it ALL. i thought the shop was reputable to and sees nothing wrong with it and my longer wheelbase helps with handle... cause i built it to take corners right!!!!
#23
it might be a little below the roll pan, but will all be powdercoated black so wont stand out if its a little low.
Shop has done many of these 4 link setups on new trucks with many satisfied customers. Im not worried about that.
thanks for the compliments guys, i will keep progress posted
