A completely different kind of project.
Old Feb 12, 2011 | 09:56 AM
Beatdown Z's Avatar
Laid Back
Good luck with it.
Old Feb 12, 2011 | 09:57 AM
custm2500's Avatar
Ph.D. in HUBRIS
The stock TB has one bearing on the far end. I plan to incorperate the same and should actualy be able to fit a bearing inside of my spring support. Therfore two bearings is better then stock.
Old Feb 12, 2011 | 10:01 AM
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by Pocket
What do you think will happen with no IAC
Assuming the rest actually work
Having no IAC will just not let it idle perfectly in all weather conditions. I will only be running the truck in warmer weather so 15-30 differance won't effect the idle speed much. Worst case I have to pop the hood and adjust the idle screw if it is really high or low at any given time. I really doubt I will ever have to change it. Just as the stock TB has a idlescrew i will do the same. Only thing is I will have to have my TB open just slightly at idle to let a tiny bit of air through as apposed to the IAC letting the perfect amount through.
Old Feb 12, 2011 | 10:41 AM
03sierraslt's Avatar
Have you ever monitored IAC counts in your tuning software to see how active your IAC is?
Old Feb 12, 2011 | 11:46 AM
outlawz2004's Avatar
I believe Justin(blackbear) tuned his truck.
Old Feb 12, 2011 | 12:32 PM
Other fine examples of your work.
sidepipes:
http://i111.photobucket.com/albums/n...0217001039.jpg
backup camera first edition:
http://i111.photobucket.com/albums/n...1-09223933.jpg
backup camera final product:
http://i111.photobucket.com/albums/n...1-17172448.jpg
cooked bed:
http://i111.photobucket.com/albums/n...x/IMAG0115.jpg
bedcover:
https://ls1tech.com/affiliates/truck...d.php?t=470798
removing front brakes to save weight:
https://ls1tech.com/affiliates/truck...d.php?t=470892
Old Feb 12, 2011 | 12:47 PM
custm2500's Avatar
Ph.D. in HUBRIS
Outlawz the side pipes were sitting on the lift and Jack stands, simply sitting there to get an idea how they look. So if you want to keep talking **** you might want to make your self look like an idiot posting a pic that has nothing but approximate placement in common with the final product.
You continue to show you idiocy with talking about my "crooked bed". Obviously you are too ignorant to understand reality.
You may not like how my screen was set up but I was happy with it. I have a larger screen that is square and getting mounted to your liking.
Old Feb 12, 2011 | 12:49 PM
custm2500's Avatar
Ph.D. in HUBRIS
It was and will be tuned by Justin.
Old Feb 12, 2011 | 12:50 PM
AJII's Avatar
Yeah, sometimes you just have to bite the bullet and pay to get it done right/get the right parts.
Old Feb 12, 2011 | 12:55 PM
Just making a reference to your last few projects, they didnt turn out so well. I would hate to be on the same track as that poor truck, your going to hurt yourself or someone else with that road hazard you call an HD.
