CHRGDUP Denali
Old Oct 30, 2017 | 07:42 PM
CHRGDUP_Denali's Avatar
Originally Posted by FFDP
I think you'd be surprised how little the exhaust manifolds itself matter. It's more about getting the air into the supercharger and through the cylinder heads. There is a reason why CTS-V's, Corvettes and Camaro's made the power they do with cast steel manifolds.
so my stock air box and tb are a bigger set back?
Old Oct 31, 2017 | 06:18 AM
smokinlmm's Avatar
Those manifolds were designed to flow a lot more than a set of truck manifolds that were designed for torque. He has a blower, torque isn't a problem anymore. When I added my kooks it unlocked an instant 30 or so rwhp. You will make more power with less boost, if you can't get the air out that your shoving into the motor you will just make heat. Get a set of long tubes and a y pipe and you won't believe how responsive it becomes! It really woke my truck up, besides the blower it's by far the best mod so far...
Old Oct 31, 2017 | 07:15 AM
that is the plan, just wanted to hear his explanation. me and my dad are actually going to build an equal length exhaust for it but have to wait until I lower it and do 2 piece driveshaft swap to make sure the exhaust will clear everything.
Old Oct 31, 2017 | 11:21 AM
FFDP's Avatar
Super Chevy did a test with a 427 stroker with a 2.9 kenne bell blower on it, they did both tests stock manifolds and long tubes on a engine dyno. The end results between the two was like 20hp and 5-6 ft/lbs just from the header swap alone. Of course results vary with application.
If someone just adds headers to an already supercharged engine they shouldn't be expecting the world from them. The scavenging effect of long-tube headers does help but someone shouldn't expect to see 30-50whp everytime.
There is likely another cause if you did see such an increase, like clogged cats, restricted exhaust past the manifold.
It's just why I commented and said they aren't the biggest player in the horsepower race. There can be more gain in other parts in the engine like camshaft, cylinder heads, compression ratio and tuning.
Old Oct 31, 2017 | 03:01 PM
that's interesting. 20hp is still 20hp though. did they run different exhaust behind headers compared to stock manifolds or kept same exhaust to strictly compare manifold vs headers? I'll be doing longtubes but will also be deleting cats and replacing stock muffler with straight through muffler at the same time. not sure exactly what the experiment entailed. on another subject, I'd like to know your opinion on vvt vs non-vvt cams for my application. already had a guy on here spec me a mild non-vvt cam that I haven't ordered yet but have really been considering keeping it lately.
Old Oct 31, 2017 | 04:36 PM
dsmmace's Avatar
Intake first, then headers. I put Kooks headers with performance cats on my stock truck. The stock airbox was definitely a restriction. Personally what I did was cut a hole in the factory lower airbox behind the headlight. I still have the factory catback exhaust.
Old Oct 31, 2017 | 08:15 PM
smokinlmm's Avatar
Intake isn't so easy with a Maggie...
Old Oct 31, 2017 | 08:56 PM
dsmmace's Avatar
You already have an intake tube, cut the lower box open or spend money. You’ll spend time and money on headers, but not do a free mod like I suggested? You’re funny! Lol
Old Oct 31, 2017 | 09:01 PM
I cut holes in the air box of my old truck. I can do that free mod you suggested for now if I wanted, but I will eventually be doing otherwise anyways. appreciate the suggestion.
Old Oct 31, 2017 | 09:18 PM
smokinlmm's Avatar
I hole sawed my stock air box already. My tuner wanted me to just replace the filter box and keep the Maggie tube. Fire up your 2.5" hole saw!
