Bonjie 2011 Build begins.. sort of
Old Jul 19, 2011 | 05:01 PM
  #181
bonj87's Avatar
new sponsored part picked up today.. its too damned hot to put it on tonight..
225 amp polished Alternator by Powermaster!
Old Jul 19, 2011 | 08:26 PM
  #182
rkwhite61's Avatar
Very nice.. I want!
Old Jul 19, 2011 | 08:40 PM
  #183
bonj87's Avatar
Old Jul 20, 2011 | 09:58 PM
  #184
bonj87's Avatar
ok guys..
i need advice on how to achieve better cooling.
running the AC, the truck will go to 215 degrees.. so i have to run with no AC.. im worried about overheating the truck and damaging anything.. help.. ..??
i have the 05 efans.. and the stock water pump.. would the meziere pump flow more and give less cooling? does water wetter work???
Old Jul 26, 2011 | 07:46 AM
  #185
bonj87's Avatar
ok i love this adjustable FPR.. but.. why when i got home.. did it read 55 psi, then i readjusted for 65 psi (should be 58 but i was compensating for the shift i saw).. this morning, it reads 100 psi!!! I know its set to 65 psi.. 30 miles down the road.. 80.. 75... finally resting between 60 and 65.. the regulator is rated at a max of 70! Im confused as to why it does that..at this point, im pointing my finger at the Glowshift guage, or that guages sending unit.. think im on the right track?
Old Jul 26, 2011 | 08:10 AM
  #186
blackcash's Avatar
I think it's because you're using it as a band aid to solve a problem. And glowshift gauges are pieces of ****.
Old Jul 26, 2011 | 08:12 AM
  #187
bonj87's Avatar
im confused.. how is an adjustable FPR a band aid solution?
Old Jul 26, 2011 | 05:10 PM
  #188
blackcash's Avatar
You have a stock fuel system. With a stock regulator that obviously didn't work. So instead of fixing it, you just went with an adjustable. Band-Aid.
Old Jul 26, 2011 | 07:11 PM
  #189
bonj87's Avatar
no you're wrong
i did not have a stock regulator... i have the tbss returnless rails on my return style system.. the band aid attempt was the vette regulator setup.. this is a tried and true solution for this conversion.
Old Jul 26, 2011 | 07:48 PM
  #190
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't trust your GlowShit gauge to be reading correctly. I'd borrow somebody's Snap-On(or whatever) test gauge, and find out what's really happening before you start chasing your tail & potentially waste money.
