Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#2021
#2022
Does anyone have a hook up at ATI (the balancer company). Not looking for a price hook up, looking to talk to someone that didn't work at 7-11 last week and this week they are professional engine builders.
I forget to get a name, but who ever I talked to today was a *****.
#2025
Well, tonight was discouraging. I had some time and was going to finish 100% of the chassis stuff and ended up getting nothing done cause I ran into a little problem. I think the issue lies in the StrongArms A-arms. I was going to set up my front end limiters and fab a bump stop. So what I did was put the dummy shocks in that are set at ride height. Take a measurement. Put the real shocks on and let the frontend hang and take a measurement to see what the total front extension was limited by the shock. The first side, I measured 8 inches, which is were I figured it would be. Then the other side and it was 6.75 inches. WTF? Got to looking at it and the shock was fully extended on the short side, so took the shock off and ran it through the range of motion and it would not come down any further. Took the tierod off to make sure nothing was binding up there and still didn't drop. Basically nothing but the a-arms connected to the frame and spindle and it binds up somewhere. Looks like the upper ball joint, but I'm not sure.
I'm gonna call Ridetech Monday and see if I can find someone there who might know whats up. I'm sure I'll get a genius on the phone like last time. Oh'boy.
Now I hate these ******* arms. Over a grand to save 15lbs and now front geometry appears to be fucked up.
#2026
I would do it. Headers aren't all that bad honestly and you have a ton of room compared to the crap I have had to work around. I use SPD for flanges but they are expensive and there are other options. You can contact Woolf Aircraft for your bends, they are by far superior in quality and CLR choices. Their prices are pretty damn good too.
#2028
Formerly ScreamingL
I have DJM arms...im 14lbs lighter then stock
I have equal travel on both sides
Im limited to upper ball joint as well but at that point i have a good bit of travel
Tyler has same uppers and reangled the balljoint mount which gave him more
The upper a arm is angled to help with driveing angle but does limit some on extensio
#2029
#2030
Formerly ScreamingL
Upper and lower...scored both for under 300...got to love summit scratch n dent deals
Pics are in my build
They have ligther tops, mine are solid bar but they also have hollow uppers
Most weight was lost in the lowers
