Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Apr 7, 2015 | 11:38 PM
  #1851
Blown06's Avatar
8 Second Truck Club
Originally Posted by slowrcsb
That's what I thought did u make a fuse and relay center or did u buy one
do u have any picture of where u mounted pcm and stuff.
I did my own, it's all mounted under the dash.
These are pics from construction:
Originally Posted by 03regcab sierra
Silly question.. Is the motor plate the only thing holding the engine in place? Allowing you to ditch the motor mounts completely?
There is also a mid plate, which is a plate between the motor and trans. You can see it in the pics. It's painted black, right now just the dowels are holding it up in the back.
Also with a set up like this you need to run engine limiters to keep the engine from moving forward and backward. I've been running a single limiter on the right side of the motor, but have noticed that it is causing some problems, so I will be adding another to the right side. Stay tuned I'll do a little picture taking and write up about it.
Old Apr 7, 2015 | 11:41 PM
  #1852
Blown06's Avatar
8 Second Truck Club
I went out side tonight to see if I could get a feel for a couple of changes that are gonna happen below the motor. I'm adding a limiter to the left side so I needed to check clearance for that and am getting a plan together for all the new cooling lines. So I snapped a couple of pics cause when I looked at it, I was like **** yeah!
Old Apr 7, 2015 | 11:54 PM
  #1853
Atomic's Avatar
I have a gauge for that
I dont know if ive ever seen so many race car parts on a truck before in one picture
Old Apr 7, 2015 | 11:57 PM
  #1854
oakley6575's Avatar
So glad you aren't one of those guys who claims "street truck" after taking your pictures
Old Apr 8, 2015 | 06:01 AM
  #1855
L8ERBRO's Avatar
You can always bend him over, I'm sure both of you would enjoy that
Old Apr 8, 2015 | 07:59 AM
  #1856
George C....'s Avatar
Formerly ScreamingL
With the mid plate, does it throw off the spacing of the bellhousing or converter?
When you had the motor plates done did you slide .motor back
Old Apr 8, 2015 | 09:08 AM
  #1857
sprayedenali's Avatar
your rotors ar eon backwards, FYI.
Old Apr 9, 2015 | 12:17 AM
  #1858
Blown06's Avatar
8 Second Truck Club
I've driven it on the street like it is. But didn't get out of the zip code. No more street driving with no coolant in the block and dry decked though. My engine builder had to warn me. lol
Yeah, we could try. Would probably need to get your instructional video to figure it out though.
Motor stays in the stock location (or where ever you want it). Doesn't change anything with the trans except moves it back the thickness of the plate, which in my case is 1/8". I did have the converter built with the plate in mind though regarding pad height and snout length.
SSSHHHH. Damn it, don't let the cat out of the bag on that trick.
Old Apr 9, 2015 | 01:04 AM
  #1859
goinbrokez28's Avatar
What's the advantage of motor plates? Why not solid engine mounts? Seems like a lot of extra weight.
Old Apr 9, 2015 | 09:45 AM
  #1860
Formerly ScreamingL
Weight and the flexing of the block....some believe head sealing issues are relation to motor mounts pulling on side of the block....if you look at placement you'll see why
Other reasons is to place motor where you need it for chassis weight, header fitment along with other reasons
