BlackGMC build take 2 - Turbo Time
Old Mar 8, 2014 | 07:21 PM
  #451
03sierraslt's Avatar
Nevermind, wrong section....
Old Mar 8, 2014 | 08:01 PM
  #452
BlackGMC's Avatar
Resident Retard
Incase yall are wondering this 90* fitting not hooked to anything is for the brake booster.
Here is how the instructions for my Fuelab regulator said to hook it up
Old Mar 8, 2014 | 08:48 PM
  #453
Atomic's Avatar
I have a gauge for that
I just feel feeding both rails is unnecessary and overly complicated. I feed the back of one rail, crossover then reg at the end of the other. Works fine. Yours should be fine, just a lot going on which means a lot of places to leak...
Old Mar 8, 2014 | 08:52 PM
  #454
BlackGMC's Avatar
Resident Retard
Ok. Yeah it is rather retarded looking. I was worried i did something wrong.
Old Mar 8, 2014 | 09:09 PM
  #455
oakley6575's Avatar
Always two ways to skin a cat. I'm going to feed both rails as well. All the fuel product manufacturers that I've seen recommend feeding both rails and every high horsepower build seems to do that. No reason not to feed both rails if it works for everyone.
Old Mar 8, 2014 | 09:11 PM
  #456
BlackGMC's Avatar
Resident Retard
I still need to buy a AN line pressure test kit. Actually i am surprised i dont have one.
Old Mar 8, 2014 | 09:15 PM
  #457
GMCtrk's Avatar
I've used several of those Summit fittings and ended up with a leaky one recently. They refunded it no questions asked and replaced with aeromotive an fitting, much better.
Old Mar 8, 2014 | 09:24 PM
  #458
BlackGMC's Avatar
Resident Retard
All those fittings with the exception of the brake booster one are ptfe style hose ends by fragola. They are ALOT stronger than you typical rubber line hose ends. I use fragola brand soley now. Always good quality sometimes a little pricy but i like them. . The only reason that one summit rubber hose end is in there is for mockup. I stopped using rubber hose ends along time ago.
If you have ever seen what long term (1 year plus) does to standard rubber braided line you would probably stop using them as well.
I have 1 piece of summit rubber ljne left on my truck. Once i get this intake installed i will post up what it looks like.
  #459
TIM Z's Avatar
11 sec. Truck Mod
Good to know , but I've never had an issue with the summit ones , they are probably made by earls or another manufacture just renamed . I like them .
Old Mar 8, 2014 | 09:27 PM
  #460
BlackGMC's Avatar
Resident Retard
Also i am just referring to gasoline usage. Not any other fluid.
