BlackGMC build take 2 - Turbo Time
Old Jan 11, 2013 | 08:05 PM
  #31
ak2007r6's Avatar
Very nice install! Looking forward to some vids and track times
Old Jan 11, 2013 | 08:09 PM
  #32
RS/SS 4.8's Avatar
10 Second Truck Club
Fuel pump and wiring
Where did you get that y fitting?
Old Jan 11, 2013 | 08:14 PM
  #33
Atomic's Avatar
I have a gauge for that
I am not sure which two ports on the FPR the port measures pressure, but I could see it always telling you the pressure is good no matter what if it measures between the FPR and the pumps. What you really want is to make sure its good at the rails, not necessarily the regulator.
The thing about PCV...when you need it the most, is exactly when you have it setup not to do anything at all; under boost. The pressure between the filter and turbo will always be lower than atmospheric. How you have it now that line will only do anything at part throttle (no boost). When you a crankcase vent the most (under boost) you have it blocked off.
Old Jan 11, 2013 | 08:22 PM
  #34
BlackGMC's Avatar
Resident Retard
I got the y fitting and hose from below. I got the crush clamps at home depot in the plumbing pex section
LFP 5/16'' Stainless Steel Y Fitting at LightningForcePerformance.com - Your American Muscle Parts Depot
I have my fuel pressure sending unit for my electric gauge attached to the passenger side fuel rail.
Whats wrong with my pcv setup? I have it setup to work only in non-boost conditions. Are you saying i am honna pressurize the crankcase when it goes into boost, meaning blowing past the rings?
So would removing the check valve attached to the intake fix that condition?
Old Jan 11, 2013 | 08:37 PM
  #35
skeet's Avatar
looks good corey! should run very well!
have boost in the back of my mind but only after i hit some goals on nitrous
Old Jan 11, 2013 | 08:38 PM
  #36
beastmode's Avatar
Import Moderator
Nice build Corey.
I can't recall your exact engine specs but don't you have a set of shaved 243s?
EDIT: Nm, reading>me lol
Old Jan 11, 2013 | 08:53 PM
  #37
Atomic's Avatar
Engines always have some amount of blow by. Under boost, you are pressurizing the crankcase, to some degree, for the same reason you have any blow by. When you dont give that air anywhere to go, its going to go somewhere, like start pushing out seals and the oil dipstick.
I would personally put breathers on both valve covers and call it good. Unless you want to replace the rear main sometime.
Old Jan 11, 2013 | 09:01 PM
  #38
BlackGMC's Avatar
Resident Retard
Cool. I got a little breather and i can go buy another one tomorrow. I just disnt want to deal with the oil smell. If it does smell great, if it does i will look into somehing else.
Old Jan 11, 2013 | 09:06 PM
  #39
Atomic's Avatar
I havent noticed any smell from mine and Ive had both vented since day 1.
Old Jan 11, 2013 | 09:08 PM
  #40
BlackGMC's Avatar
Resident Retard
A buddy of mine mentioned his smelled sometimes. That is where that idea came from
