Another new one in the stable. 71 Pancho.
#21
I have heard of some people building 350s for boost or just shooting them with nitrous. I believe the group is called Pontiac Odd *****. They only build 350 and smaller motors. I looked into building the 350 but research indicated to me that performance potential was very limited and it was more economic to build a large bore pontiac.
Richardman1992 (03-24-2021)
#22
#23
https://www.facebook.com/groups/815586749225492
If you are a fan of Pontiac engines, a true fan...then you are aware of how hard it is becoming to find a good use-able larger Pontiac engine core. This group will be dedicated strictly to those Pontiac V8's that are of the smaller nature and how to work and modify them.
Anything goes as long as your build is started or based on the original small cube PONTIAC block. and not the larger more mainstream engines. The exception is if you use a 400 block and de-stroke it to a 303 or smaller cube. Pontiac 4 and 6 cylinder engines are also allowed.
None of the bigger Pontiac engines allowed.
Richardman1992 (03-26-2021)
#24
Here is the link for the group. They are super friendly and share tons of info with each other. If the admin doesn't let you in ping me and I can message him.
Just sent a join request and answered the questions. I’ll pm you if I don’t get approved
#25
Its been a while since I have updated this thread so here are the updates. The car is looking really good and I've brought it out to a good number of cars and coffee's. Gotten a lot of good feedback on it. People are loving the car so far. I just finished up the install of the 4 corner disc brake kit. It uses 11" rotors all around. Aside from that it looks like the LS Swap is still in budget and progressing slowly. I imagine I will start in about two months if everything goes to plan.
Car mods to date:
17-9 3ed gen snow flakes. maybe should have gone wider in the back. these really needed a .5" longer wheel stud all around.
formula wheel conversion with real gm wheel off Canadian car. not junk repop
1" taller forged upper ball joints
UMI springs stock height high rate, already cut 1/4" coil and still a bit high in the front.
Bilstein shocks
1-1/4" front sway bar
1" rear sway bar
entire steering system is new with Borgerson box. aligned in garage old school way.
oem style boxed rear lower control arms w/ poly bushings
rebuilt the rear end with a 3.55 auburn and repainted
new rubber body mounts
4 corner disc brakes with parking brake
went around entire car and remediated any rust, cleaned off any failing paint and restored or undercoated as appropriate.
repainted fender liners, various brackets core support
new rocker mouldings, gto style
removed all carpet and dynamat 80% of the floor.
pontiac hood tach
rally gauges conversion
correct oem 1971 rally clock (always gonna show wrong time anyways lol)
ls swap parts obtained:
lq4 with gen4 rods and tick cam
4l80e with stock van converter
swap wiring harness and 2002 pcm
l92 heads and intake
holly oil pan headers motor mounts and crossmember, holly swap exhaust
fixed displacement denso compressor
need to order:
radiator (actually ordered but backordered 2 months)
drive shaft
electric to manual speedo box
ac line kit
vintage air condenser made for 134a with drier and built in binary switch
not sure if poa set for 134a or not need to investigate
fuel rails pump assorted lines and fittings for fuel system and tranny cooler
Car mods to date:
Bilstein shocks
1" rear sway bar
pontiac hood tach
need to order:
drive shaft
ac line kit
RedXray (07-03-2021)
RedXray (08-07-2021)
The following 2 users liked this post by RedXray:
68Formula (08-07-2021),
zz454Chevelle67 (08-09-2021)
